The Vid I Should Have Posted
Same race as the last deal...just a better angle and in HD
http://www.youtube.com/watch?v=XDngjg71tFI
back tire and the break in the 1/4 for a 1000 bux
Re: The Vid I Should Have Posted
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I looks like a heads up race or very close to it and both of you were asleep at the tree.
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
nice job bro, glad to see the car is working nicely, now come give mine the "tuneup" chitown style
Car: 1984 Z28
there are no times posted that i'm aware of since he's a grudge racer like a few of us survivors
Car: 1984 Z28
why use the tree when he's getting spotted out and given the "hit" to make up for the other guy having a better setup. no different than if they wanted to yawn bracket race, the tree comes down at a different time.
exactly, basically if you see me racing on something as ghey as a sportsman tree there's some ninja sh*t goin on
Car: 1990
Axle/Gears: stock
very nice run - i did not expect that front end to come off the ground - you are lucky you had the break or he would have taken you,
how much do you think you could improve your run if you kept the front down and not wasted horse power lifting your front instead of moving your butt forward?
Car: 1990
Axle/Gears: stock
BUT I BET YOU WILL! using that power to move you forward will get you an extra second or two. you lift at second 46 and at 48 you are down. that is two seconds that you are losing torque moving forward instead its holding your front end up. in a race that only lasts a max of 10 seconds according from your timer on the tape - that means for 20% of the race you were not under full power.
so lets see you run again and keep that front end down. looks like you got tons of torque - just fine tune the gearing to get is all moving forward.
but it is a darn fine machine you got and takes a heck of a wheel man to keep it on the tract in the best of circumstances and running 2 seconds with no steering and the front end blocking your view - damn fine driver you are.
Car: 1984 Z28
man i too hope I can keep my nose down to run 2 seconds quicker as well.....
unknown_host
06-13-2003 06:38 PM
poorboy8
Mid-Atlantic Region
09-28-2002 08:31 AM
