first time out with 325s
First pass had 17psi no air in the air bag I launched at 15lbs dead hooked but pulled hard right had to let out. Then I air the bag o 25psi it hit the tires harder and spun let them down to 13psi where I ran my 275s I launched at 13lbs 1.45 60ft. That's th best 60 I've got on a friday tnt.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: first time out with 325s
Great man, can you tell if there was any contact to the tires by the body?
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
that pressure seems really low to me, but i'm also running less power at the moment. did you get a decent clean pass in?
I guess its because my car weighs 3020lbs with me in it that it requires the low pressures I haven't seen what others with cars as light as mine run for pressures. I had the one clean pass 1.45 60ft, 4.400 330ft, 6.85 @ 99.85. I have way too much gear. I bought a rear from a guy that ordered it with 4.30's and my turbo doesn't like them at all. I going back with a 3.23 or 3.42.
