mini tubs
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: mini tubs
Look through the fabrication board. There's lots of topics on mini tubs.
Re: mini tubs
It's very different than the typical mini-tub. Most people just modify the existing wheel house. - Between the unibody structure and suspension placement there really is no reason to try to cut the tub completely out and install a full "mini tub".
Car: 87 IROC L98
Re: mini tubs
Unlike older cars where the frame rails are considerably inside from the inner fenders, third gen frame rails are right at the inner fenders. You can't make them wider than they already are but modifications can still be made to accept a larger tire.
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
Re: mini tubs
Check this out it helped me when I did it.
https://www.thirdgen.org/forums/orga...5-15-mods.html
