Finally got a decent pic of the wheels up
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
Well, not a high as other cars on the board, but at the time of this pic last year, she weighed around 3600 with driver and still had the A/C installed.
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Re: Finally got a decent pic of the wheels up
very nice looking car, what are you running for wheels/tires for size and backspace
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
Thanks guys!
The wheels are Weld Draglites 15x8 in the rear with a 4.5" BS. Slicks are M/T 10.5 x 28's
The front rims are Cragars (pretty much same as the draglites) and are 15x4. I don't remember the BS at the moment
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
sick.. wish mine would hook like that..
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Sweet! Heres a stupid question. If you hook with NO spin, how much horse does it take to lift the wheels on a 3500 lbs car? 350? 400? 450+? I''m sure a stall helps too right? Never dragged before, only watched.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
hp is relative when you consider converter/gear size and/or clutch type/launch rpm. my 305 put down 243rwhp and would lift the front left tire 3" off the ground.
Car: 1984 Trans Am
think a bicycle.. if you pedal while leaning over the handlebars, you will never lift the front.. but if you lean forward then suddenly all the way back while pedaling its very likely you will do a wheelie.. weight transfer..
ambainb
04-25-2016 09:21 PM
Polo Z03
09-10-2015 06:43 PM
