Skinnies, spacers, and c5 brakes
can it be done? i know that for c5's there are bogart and ccw "drag packs" that are $$$, and clear the front rotors, and draglites will "work", but i believe that is after putting c5 rear brakes on the front. all the above info is without spacers, i currently have c5 brakes, and rims that have 1.5" or 2" spacers on them, so could i get some skinnies that would clear my brakes with these spacers, and still ahve the skinnies be wide enough for mild street driving?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Skinnies, spacers, and c5 brakes
I was working on trying to fit C4 or maybe it was C5 brakes on my car and they wouldn't fit with skinnies. Using spacers, I would have had to push the wheels out about 2" to clear the calipers. Large rotors and the large multi piston calipers are designed for 16+" wheels.
I ended up just putting an Aerospace front brake package on the car.
Car: Iroc-z 86
Engine: 350 4bbl
Transmission: built up 700r4
Axle/Gears: ls1 4.10 posi
i have skinny with my ls1 front brake....with 2" spacer its about 1" out of the fender....rims are 15x4
doesn't look that bad, but i dont roll them in the street, there is so many pothole over here.
Seb
Seb
here's a mockup picture to check clearances (before i bought new calipers/pads) with my ls1 brakes and a billet specialties street lite wheel. this wheel is very inexpensive for a billet wheel. 15x4 with a 1 5/8" backspacing and a 1/4" thick spacer.
you can see in this picture how the wheels sit in the well, perfect if you ask me
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
This is exactly what I'm attempting. The 15" wheel diameter fits over the caliper, but has just about no clearance probably in the range of 1/16". The Summit street star wheels I have need at least 3/4" spacers to move the spokes away enough, but I'm thinking I'm most likely going to get 1.5" spacers that should also let me fit wheels from an LS1/C5/C6. I haven't totally studied it, but I'm thinking some grinding on the caliper abutment will let me bring it towards the center of the spindle for more clearance.
SebasIroc: Might want to check for tire clearance. It looked to me like a 2" spacer would have the tire swinging into the front and rear of the wheel well with the new arc it makes.
Car: Iroc-z 86
Engine: 350 4bbl
thanks fast, I will check for tire clearance when spring is back, never really feel any rub, but never had to do tight turn....since they are only on at the track.
Seb
Seb
wow, i couldnt have asked for better responses! m66nova, i love those wheels, but i perfer prostars for the look im going for, do you think they have the same dimensions with a different design one the face of the wheel? and how are skinnies for street driving? i dont want to make my car useless on the street.
they have a completely different style of joining the center section with the rim portion of the wheel. i have much much much more clearance than the pro-stars.
as far as the drivability is concerned, i'll let you know in about a month as i don't have the motor in the car yet.
Car: projects.......
fast82z - you could easily grind the cooling fins down on the calipers for more clearance. It's not like you're going road racing on the skinnies anytime soon.
As Matt stated, the billet wheels have a lot more room out by the wheel lip due to their construction vs. a cast/forged wheel.
I'm glad to have seen this (actually saw it on YB first). I was hoping to be able to run a bit larger brakes and still fit skinnies on the hard tp I'm putting together. For those with forged wheels you could probably run regular/non-GS C4 vette rotors(or 1LE and not have to turn stockers down to hubs) and C4 vette calipers. 12" brakes and twin pot calipers would still be a considerable improvement, but less likely to have clearance issues.
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
The fins aren't where the issue is. The spoke area on the outer part of the caliper is why I need the spacer, and the smallest outer diameter of the caliper is just really close to the wheel.
Gotcha - don't really see that in the pic, but it makes sense. - Don't the 4th gen guys have to run spacers to fit forged skinnies? It would then makes sense that we would have to to run the same brakes.
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
I bought 1.5" spacers to use there, but like I said a 1" spacer looked to be plenty. I ended up going with LS1 rotors because I changed my mind and am using the stock 15" Z28 wheels instead of the skinnies. Might I add, the LS1 brakes all around are great compaired to the stock front disk and rear drum setup.
Car: 1985 camaro z28
Engine: 355 sbc what else
Transmission: TH 350 manual vb/ 4200 stall
Axle/Gears: 4:30 on the street
well this thread just answered alot of question that i had about ls1 front brakes. just wanted to know who turned down your stock rotors, that way i can get working on it.
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
I just got some ebay spacers. They were a pair for about $60. There's better ones out there that maintain a hub centric fit, but these seemed just fine.
[quote=Shagwell;4157765]Any machine shop/machinist with a lathe can turn them down. It's a fairly simple job.[/quot
cool man i thought i would have to fond someone with one of those brake turning lathes to cut the discs off. i have a buddy with a lathe and we have dicussed doing it but we were not real sure of a good way of chucking it to the drive head. if by chance you got to watch yours get turned, i would like to know if you remember how they chucked them to the lathe.
thanks man, i may have to go get some ls1 rotors and give my stockers the cut
[ON] 9 Bolt Axles Partout
6speedIROC
16
03-15-2023 08:33 PM
