1/4 mile and 0-60?
Car: 86 T/A WS6/Future project
Engine: 350 TPI/ Pontiac 455
Transmission: 700R4/TH400
Axle/Gears: Posi.
1/4 mile and 0-60?
Hi im currently doing a 455 pontiac engine swap with a th400 tranny into an early third gen and i was wondering if anyone could give me som estimates about what times i would run and stuff. The engine is a mild build with a mild cam mostly everything else is stock. thanks gary.
Axle/Gears: Posi.
Re: 1/4 mile and 0-60?
come on im sure someone can give me some estimate.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
12-15 second 1/4 mile time. With all the info provided, that's the best guess I can do.
Car: 89 camaro rs
Engine: 406sbc
Transmission: 700r4 2800 stall
Axle/Gears: 4.56
1 Post
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
If you were seriously concerned with 1/4 mile times, you would probably see some mid to low 14 seconed times and with about 3-5,000 worth of drivetrain improvemants (gears,exhaust,tires,trans, conv. etc...) you might have a 13.50 in it.
good luck and post some pics
Axle/Gears: Posi.
I don't know what you are calling mild. How about some info on the gear ratio, cam size, compression, converter stall, intake. How much horsepower are you expecting to make. I would say a mild street build in a 455 should get mid to high 12's, but then again what is mild?
Axle/Gears: Posi.
i know my intake would be an edl. performer. and the compression is 8.5/1.
Car: 89 camaro rs
Engine: 406sbc
Axle/Gears: 4.56
With that kind of compression and intake I'm assuming tht your build is going to be very mild. Realistically, high 13's will probably be the best you will pull with such a mild set up. If you are new to racing a mid 13 second big block will outrun most of the small block's that show up in a street class. I run mid 12's and usually am one of the quickest cars at our track.
Axle/Gears: Posi.
ok thanks im just looking to beat my friends wrx with 250-275hp he talks alot of smack being the fastest car in the parking lot. his parents pay for everything on it.
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
86CamaroDan
09-29-2015 10:08 PM
