WOW 9.95 on motor with 93 oct.
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
First time to the new palm beach international raceway and came home with a new best!
first pass: 1.41 60ft with a 10.06
second pass 1.38 60 ft with a 9.97 @ 134.27
third pass 1.37 60 ft with a 9.95 @ 134.08
All done on 93 oct and thru the mufflers on DOT radial street tires.
I fell lucky I think I am going to play the lottery.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: WOW 9.95 on motor with 93 oct.
that's awesome man! i bet you can't wait to hit the nitrous now...i see 8.9x's in the future for that car!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I'd love to race at sea level or in conditions with air below sea level some day. I'm always struggling at high altitude. At least I don't have to race in Denver.
Car: 82 camaro
Engine: 434 ci
Transmission: t400
The weater was nice 57-59 deg I was worried I would not get the ticket with the head winds we had.Stephen load that car up and come on down, track is working great.Fast 82 the headers are hooker long tubes 1 3/4 cam is pretty good size soild roller. MW man with the luck I have with this motor and the economy I think I just may keep running it on motor I have a new intake for it a motown,I home ported we will see if that helps.
Car: 82 camaro
Engine: 434 ci
Transmission: t400
No pics I never take the camara to the track. If I can figure out how to use my scannner I could post the time slips.
Car: 1986 IROC-Z
Engine: SBC
Transmission: Manual Th-350
Axle/Gears: 9" Moser 3.89's Spool.
I think ive mentioned before that im building almost an identical car. If I can get it to do 9.95's on motor, im gonna do backflips.
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Yes I changed the converter and gears. I bought a PTC 8'' 5500 stall converter and put a 4.10 gear in it I also switched the 950 hp carb for a 1050 dominator. Those are the only changes from Orlando.
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
on a 275 or 295 drag radial? i see you mentioned in another thread the 295's slowed it down a bit on motor.
nice times!
nice times!
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Slow your boy from UPR was out there fri night. I hear you are very close to running agin.
