Post pics of third gen Race cars.
1 Post
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
This could be a re post but I want to see some new pics. Here is a thread with a lot and it looks like some of you already posted up.
This forum should have this thread.
http://www.yellowbullet.com/forum/sh...pics+third+gen
1 Post
Car: 1986 Camaro SC
Engine: None
Transmission: None
Re: Post pics of third gen Race cars.
Yeah, I thought that thread should find its way here at some point.
1 Post
Car: 1991 Z28
Engine: 400 ci LS3
Transmission: Jerico DR4
It may not be as fast as a lot of you guys, but it did leave the factory as a race car, and sometimes it thinks it's a race car.
street.strip car but next year it will be a strip only car
Car: 84 Berlinetta
Engine: 360
Transmission: 350 turbo
Axle/Gears: 9"/4.11
more strip action occasional street
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The majority of TGO members have street/strip cars and not dedicated race cars like most of those pictured on YB.
I frequent YB for information but have never registered to contribute.
Since this web site is dedicated to third gens, there doesn't need to be a specific thread to just show racing cars. Many people posting to the racing forum already show a picture of their car.
The majority of the TGO forums are also tech orientated not general discussions. That YB post is in a non tech forum.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Still street strip, more strip than street anymore though, just not as much free time like there used to be, but it gets driven when i have the chance!!!! if i want a full out race car i will buy a engine on a stick.
$500 1st year beater
after:
after:
1 Post
Car: 1986 Camaro SC
Engine: None
Transmission: None
Not to mention, that thread is a great thing for other people who enjoy seeing the potential that third gens have and it can also inspire and motivate anyone with a goal or project and also give them ideas.
1 Post
Car: 1991 Z28
Engine: 400 ci LS3
...there doesn't need to be a specific thread to just show racing cars.
Car: Camaro RS
Engine: 415 c.i.
Transmission: Glide
Axle/Gears: 4.56
This is from the end of '06. It has been a while since it has seen the track. Last time it was at the track it ran 10.38@128. It will finally be completed for next year and will be in the 8.80-9.00 range with the help of a 415ci small block. Sorry I had all my good pics on a different computer.
1 Post
Car: 1986 Camaro SC
Engine: None
Transmission: None
I thought you had a black/gold car? Have any pictures of that one? Still selling the roller??? I bought 2210's and a powermaster starter from your friend with the black convertible.
Car: projects.......
I need to get some more photos up-loaded to photobucket. I'm usually online from work, so I don't have access to most of my photos.
The car is almost finished now. It's set-up for 10.5 outlaw.
Car: 87 IROC L98
I like those headers. I need to make a set like that.
1 Post
Car: 1991 Z28
Engine: 400 ci LS3
Thanks. That is my first set of headers, I'm fairly proud of them. If you want I can post up some build pics of them. I have pics of each stage of each primary tube all the way up to the completed headers. Plasma cut flanges and mandrel u-bends, not a kit. They're 2-1/4 primary, 5" collector. I've got to build the mufflers and install the O2 bungs yet.
http://s455.photobucket.com/albums/q...erprimary4.jpg
http://s455.photobucket.com/albums/q...eringshaft.jpg
http://s455.photobucket.com/albums/q...imaryfinal.jpg
I've got a crap-load more on my home computer.
The struts are tied to the upper strut plates(I fabbed up the sphericals using the stockers as a template). The towers are tied to the cage strut pipe. - The whole car is a DIY job. I'm too poor to do it any other way.
http://s455.photobucket.com/albums/q...riverfront.jpg
1 Post
Car: 1991 Z28
Engine: 400 ci LS3
Car: Camaro
Engine: 305-150/254 combo
Transmission: TH350 or T200
Axle/Gears: Srange 12 bolt; 5.14 or 5.38
A couple pics of my Stocker.
The towers are stock, just braced to the cage/strut pipe that runs through them. The caster/camber plates are custom diy built with a spherical mount for use with coil-overs. - There is no factory dash support or cowl area in the car at all. Just a dash cover and column tube(alum pipe type).
thanks! It's completely diss-assmebled right now, just finishing up painting everything. Should be going back together this weekend for the final time, wire it up and a couple other things next week to be ready for the following sunday t-n-t.
I'm not going to have the blower on it just yet. I've only made on 1 pass in the car before, and then I tore it apart to do all the work. I couldn't fit in the car comfortably, and it still had the stock k-member and a-arms in it. - I was in commission based sales, with the current economy it was either get the odds & ends to finish up the 1471 or finish the car and drop one of our NA motors in and go play. I opted to get some seat time, hopefully sell a motor or two and then finish up the new blower. - I kinda wish we still had the 871 set-up that was on the '68, I'd be ready to play.
I really like yours, very clean. My next project is an '86 bird that going to be a stock suspension radial car. I've got a 96mm squirrel strainer for it, probably end-up going bigger.
Stage20- nice interior that turned out very nice!!!
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
Some of my early 1.60, 60' pics (its all I got)
^^^ that's how I'm planning to to do the strut pipes in my radial car. I can then tab the block plate to the front curved kicker legs. Some B-E-A-UTIFUL rides on here.
wow man! I hadn't seen any full car shots of yours before. That thing is gorgeous! I hope my radial project turns out that clean.
- it won't let me edit the other post and I moved a bunch of the exhaust pics around on photobucket and added a bunch more. This link should get you into the album, for those who want to look.
http://s455.photobucket.com/albums/q...rimary2top.jpg
burke561 (10-03-2023)
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
jeff moyer's BEAUTIFUL car
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
my friend Brian's stocker...MPS helps sponsor my car as well...
last but not least....mine before the black'd out front lip and with half my contingency decals pealed off...
#44
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
stage20 your car is *******! scary and sexy at the same time. i love those gold welds:thumb:
#45
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
not too scary though. the last time i ran at the track i had people asking me if it was a turbo cause they couldnt hear my car go down the track.
just running a stock replacement dynomax muffler. need to go duals or something, im sure its holding me back, but i like it quiet.
#46
Car: 1983 trans am
i got true duals with an x and magnaflows.... you can barely hear my car in the vids
#47
anyone have anymore pics or info on this one?
#49
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
