Post pics of third gen Race cars.
#301
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Re: Post pics of third gen Race cars.
#302
Car: 91 Bird
Engine: Pontiac 500 + CID
Transmission: 3 speed auto
here is mine...Pontiac Power! Stock suspention/wheel well/springs/a-arms/using the factory gauges. ED Quay did the cage and picked the struts/shocks. I had a 477 in frist than a junk 467...next will be a 535 cid. Best ET was with the 477 it went 9.19 @ 147 MPH back in 2003.
#303
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
wow...thats a sweet 'bird. we have some hard launching red 'birds on here, between this one ^^ and IHI.
#305
Car: 91 Bird
Thanks...yes its a true 28.5 x10.5 MT slick...but on the car now are 275/60/15 goodyears.
#306
Car: 1987 Pontiac GTA Trans Am
Engine: Basic Stroked SBC..383
Transmission: PerformaBuilt 700R4 3000 Stall
Axle/Gears: Moser 9in. 3:70s
Lovin the Pontiac motor man..what do you think of Butler Performance? IF I have enough $$ when my sbc stroker goes..I guess I have to get it done and running for that to happen lol..but I plan On doing like a 461 or somethin..one day
#307
Car: 91 Bird
Butler is the MAN! I buy stuff from him all the time! A guy running in Ram Racing D/R class has a Butler motor running high 8's @ 152.87!!!! hers is the frist pass with out the bars on the car!
#309
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
92stealthramz...not my favorite color car, but the convo wheels and wheelie bar make the look work. beautiful launch!!
#310
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Wow This thread is OLD! my car has changed quite a bit as Im sure everyone else`s has too. So I`m throwing up some recent pictures of this junk!
First Time into the 8.60`s
![Name: 4719025003_a987a7fc08_b.jpg
Size: 103.6 KB](https://www.thirdgen.org/forums/attachments/organized-drag-racing-autocross/403889d1501447131-post-pics-third-gen-4719025003_a987a7fc08_b.jpg)
First time into the 5.40`s in the 1/8
![Name: 5091420151_7445d5a28a_b.jpg
Size: 94.5 KB](https://www.thirdgen.org/forums/attachments/organized-drag-racing-autocross/403890d1501447131-post-pics-third-gen-5091420151_7445d5a28a_b.jpg)
Picture of the 498 with two kits
![Name: 015.jpg
Size: 114.7 KB](https://www.thirdgen.org/forums/attachments/organized-drag-racing-autocross/403891d1501447131-post-pics-third-gen-015.jpg)
First 160 mph run (cracked the sleeved block too)
![Name: 021.jpg
Size: 111.9 KB](https://www.thirdgen.org/forums/attachments/organized-drag-racing-autocross/403892d1501447131-post-pics-third-gen-021.jpg)
On the way to the first 8.5X run!!![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
(throwing the house at it!)
![Name: _DSC0442_edited-1-1.jpg
Size: 94.5 KB](https://www.thirdgen.org/forums/attachments/organized-drag-racing-autocross/403893d1501447131-post-pics-third-gen-_dsc0442_edited-1-1.jpg)
Lets see those updates!!!
![Name: 015.jpg
![Name: 021.jpg
#311
1 Post
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Not all of us are making 8.50 progress...
j/k that looks great.
I think I took a few steps backwards as my car has been tieing up jack stands for about 3 months waiting to sump my tank and install my 9 inch and new Tubular suspension.
I do have a feeling that after I get that stuff done it will be down hill from there.
Hopefully!
Hopefully!
![help](https://www.thirdgen.org/forums/images/smilies/help.gif)
#313
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
i guess ill throw an update out there, but im sure most have seen the pics already.
pretty much the same deal, just a bigger motor, kirkeys and a rollbar.
6.20's on motor.
![Name: TJ17-1.jpg
Size: 79.2 KB](https://www.thirdgen.org/forums/attachments/organized-drag-racing-autocross/403887d1501447105-post-pics-third-gen-tj17-1.jpg)
6.20's on motor.
![Name: TJ17-1.jpg
![Name: DSCN2218-1.jpg
Size: 115.4 KB](https://www.thirdgen.org/forums/attachments/organized-drag-racing-autocross/403888d1501447105-post-pics-third-gen-dscn2218-1.jpg)
#315
Yep thats great! how many inches is that LSX now? last time I ran on just the motor it was not much faster than that, 118 6.0 is what I recall
#316
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
408ci
tfs 235
camshaft is only .247 duration .623 lift
id like to port the intake and heads, and go with a lil bit bigger stick down the road.
ive yet to put gear in the car. only a 4.22 with a glide.
4.71 is getting setup in the off season. i hope to see home high teens.
we'll see.
tfs 235
we'll see.
#317
the old 9inch tires
100_1379.jpg?t=1288210955
![Name: 8-251B1012.jpg
Size: 117.2 KB](https://www.thirdgen.org/forums/attachments/organized-drag-racing-autocross/403865d1501447092-post-pics-third-gen-8-251b1012.jpg)
![Name: get-attachment.aspx.jpg
Size: 43.3 KB](https://www.thirdgen.org/forums/attachments/organized-drag-racing-autocross/403866d1501447092-post-pics-third-gen-get-attachment.aspx.jpg)
now running a 28x10w
![Name: slicks.jpg
Size: 38.2 KB](https://www.thirdgen.org/forums/attachments/organized-drag-racing-autocross/403867d1501447092-post-pics-third-gen-slicks.jpg)
![Name: slicks2.jpg
Size: 32.4 KB](https://www.thirdgen.org/forums/attachments/organized-drag-racing-autocross/403868d1501447092-post-pics-third-gen-slicks2.jpg)
best of 12.37@ 112 @ 9psi so far and that was with a dyno of only 270/370 rwhp/tq
car will go 11's if i ever get rid of the 4:10 gear for some 3:42's
new combo is at the machine shop almost complete destroked 3.4L v6 brings it down to 3.0L solid roller cam,11.03-1 cr 70mm turbo for testing, swaping to a bw s475 later.
oh yeah almost for got since most of u sen the cr and prolly went huh 11.03-1 cr with a turbo,new combo is setup to run on e85
![Name: slicks.jpg
![Name: slicks2.jpg
#319
well at least you got some chicks in the picture!!
#324
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
matt what happened to the cowl hood... and the efi? i must have missed a thread here or there.
#329
Hey greezemonkey--
when you throw away that " junk " let me know---
I think I'll be " junk collector " that day LOL...I'll take the " house " too!!![lmao](https://www.thirdgen.org/forums/images/smilies/lmao.gif)
Very envious of all these 3rd gen race cars!! VERY NICE everyone!!!
#330
i ripped the efi off shortly after i paid for my first tune. i realized that i wasn't happy with the car and wanted to make changes. i didn't like the idea that in order to tune the car, i was going to have to front like $700 into tuning equipment, or make another 5 hour trip to get another tune. i couldn't even change shift points without the help from someone with the equipment...so when the 4l60e tore up, and the bottom end of the motor came apart, i took the efi off and put a manual valve bodied transmission in the car. best decision i've made the entire time i've own the car.
#331
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Well I might as well post some updates. I didn't get any action shots this year.
These first 2 pictures were taken right at the end of the 2009 season. The sun was dropping below the mountains and reflecting off the bottom of the clouds for some interesting lighting. Black cars are so hard to photograph. Flat black is even harder.
![](http://www.hardtail.com/pics/forum/sept25-2.jpg)
![](http://www.hardtail.com/pics/forum/sept25-4.jpg)
The next 2 pictures are at the end of the 2010 season. One of the car, the other of the engine.
![](http://www.hardtail.com/pics/forum/End of 2010.jpg)
![](http://www.hardtail.com/pics/forum/engine-2010.jpg)
#337
#338
Car: 87 IROC L98
Yes. I masked them all off to paint. It was difficult to mask and see the dual flames at the same time. It was hard to see the final result until the last pinstriping was done. The flames were first done in a white base coat to make them brighter. They then got a complete coat of yellow to cover all the white. Finally the ends were given orange with red tips. That was all painted with spray cans so the color transitions are not nice and gradual but they look good in pictures and from the grandstand. I finished off the flames with a light blue pinstriping. The painted pinstripes are not perfect but they enhance the colors. The flames on the T-tops were done the same way but the color transitions are a little nicer. They also don't have a dual flame pattern.
My flames will not win any contests for best paint but they're a hands on, DIY flame job at minimal cost. The main reason I did the dual flames is because I didn't want a white or yellow nose on the car. Having black flames over traditional colored flames solved that problem however if you see the pinstriping, you'll notice black pinstriped flames over black paint. It was the only way to accomplish the effect. When I put fiberglass doors on the car last winter, I had to redo the flames on the doors. The passenger side door looks better than the first ones I had but I'm still not happy with the final shape of all the flames. I think the licks are all too big but that's my own personal opinion.
As for that above wing, as much as I'd love a wing, the factory spoiler seems to do a fine job for me. I've never had a handling issue at the top end due to not enough downforce but then I'm only running in the mid 140's. I'm really not sure if a wing like that that would actually help me or not. My deck lid is a piece of aluminum held on with some Dzus fasteners. There's an air gap under the deck lid at the back so there's isn't a lot of stiffness if a lot of downforce is applied to it.
What about the wing struts? They're attached to the bumper cover. I have nothing behind the bumper cover so the struts would be attached to rubber. Just how strong would that be if the wing was applying a lot of downforce?
I like the Ed Quay wing on greezemonkey's car but I wish the side plates extended down more to reach the factory spoiler side piece mount holes.
A big wing like that would make my car look faster but most people don't believe it runs as fast as it does now. The low profile cowl and aeroscoop hiding the tunnel ram and BBC is what probably throws them off the most. Add in the race mufflers for a quieter engine and it's really deceiving. Those screens on top of the toilets are food sieves purchased at Walmart. They're a perfect fit. The dent in the top of the front one is from the scoop hitting it. That's how close the clearance is.
#339
Sick Man, Sick....rock the wing! you got it so rock it
Whats this thing gonna run, your guess..
I know many guys saying they dont have issues but I can say for sure I did at 150, dropped the wing on and no more white knuckles, I can drive thru with my pinkie finger on the wheel, almost takes the fun out of it but hey, gives me time to look at the gauges and other lane at over 160 mph now, to ed quay I say
![doh](https://www.thirdgen.org/forums/images/smilies/doh.gif)
![thank you](https://www.thirdgen.org/forums/images/smilies/thanks.gif)
#340
Awesome pictures Stephen, very artistic and I love that launch shot from the rear.. whats your corrected et for say 600 ft above sea? I see in the goals thread you said its been 9.20`s..gotta be some deep 8`s at sea right?
#341
i've been emailing back and forth with racecraft about their new wings. they have some shorter ones that give you simiiliar effects for cars not going quite as fast. they told me (without me telling them how fast my car is running) that even a car running 120mph will benefit and will likely show small ET gains.
#342
Car: 87 IROC L98
I use a bunch of dyno correction formulas in my laptop to predict an ET based on weather conditions. Theoretically, at sea level in "standard day" conditions, the car "should" run a 8.85. It's unlikely I'll be racing at sea level any time soon so I'll just have to be happy to make HP restricted altitude passes. At least I'm not in Denver ![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Whenever I hear someone say how fast they run, the first question I ask is where? If you have a 12 second street car in Denver, great, let me shake your hand. That's a fast car. You have a 12 second street car in Florida or any other sea level track that can have air conditions below sea level (Mission BC in the spring and fall)? Big deal. Lets see how much it can slow down when it's at altitude.
As much as I'd love an 8 second timeslip, I don't want to travel to a sea level track or have to use a power adder to do it. It's pretty bad when I say 3500' density altitude is good air for me.
If I want to run deep 8's, I'd need a much lighter vehicle. Build a tube chassis third gen or drop my engine into something like an altered.
Since I have no major expenses this winter (didn't break anything this year), maybe I'll consider purchasing a wing. I'll miss the factory spoiler. I was actually wondering if I could design a wing. I can get more sheet aluminum for the deck lid and redesign the lid to extend out to the chute as a wing. Fabricate the side plates and some braces for underneath. That way the wing and deck lid would be all one piece. It would be harder to take off but I never remove the deck lid anyway. The battery is in the back but I have charging posts mounted in the bumper cover.
How thick is the wing material? The sheet aluminum I can get is around .060" but I think that may still be too thin.
#343
Car: 87 IROC L98
OK. I think I just answered my own question. I was looking at the Racecraft and Ed Quay wings just to see how they look. Very nice. I know both are not available locally so I went and looked at Competition Engineering's universal wings which may be available locally. They're actually a Moroso wing. Right in the description it says "The main spoiler and spill plates are fabricated from .050" clear anodized aluminum" so I guess the material I can get is more than enough. It's just not pretty anodized aluminum. Nothing some paint can't fix.
#344
Yep .050, Id do it, you have homemade everything else and if you have access to a brake thats all you need, well a shear would help as well. most of the major race car fab shops sell just the strut kits, ed quay does but you say you cannot order from him right?
#345
Car: 87 IROC L98
Cross border shipping always sucks. I've been digging around. I think I can fabricate just about everything I need including struts. It'll be one of my winter projects. I should be able to make a good functional custom wing/deck lid for less than a couple of hundred bucks worth of material.
#346
Great always like the projects you do with the write ups..hint hint
#347
Car: 87 IROC L98
I've seen lots of pictures to know what I need to do. Just haven't decided on the final style yet. I was really thinking about doing a fabrication write up. My wing will be a custom piece. Since my deck lid is already a piece of aluminum held on with Dzus fasteners with the factory spoiler attached, the new deck lid will be recut and extended out to incorporate a wing as all one piece. Unbolt the Dzus fasteners, disconnect the struts and completely remove the wing/deck lid if required. I don't think I'll design an adjustable wing though. I'll angle it up slightly to give a bit more downforce and make solid struts.
I'm still digging up more small parts.
#348
Car: 87 IROC L98
Actually, I wouldn't mind seeing a couple pictures of that Ed Quay wing. Looking down from the top along the sides and maybe the underside in the same area.
#349
Car: 87 IROC L98
OK, the drag wing was getting off topic so I created a new thread in the fabrication forum. I'll use that to show my build progress.
https://www.thirdgen.org/forums/fabr...brication.html
#350
Car: Z/28
Engine: 355
Transmission: Turbo 400
here is the link to some pics of my car with a Quay wing on it.
https://www.thirdgen.org/forums/sout...-here-pt2.html
