3300 lbs
3300 lbs
Got the car weighed in street trim again today
not the same scale i used last time but certified to be guaranteed. Dont know the plus or minus but i hope its not nearest 100
bone stock 89 Irocz last year was 3400lbs
This year with new 383 with aluminum heads/waterpump, ministarter, NO INTERIOR at all except for 2 corbeau forza seats with power everything still, power seat, windows etc, and 8 pt roll bar
3300 lbs
So with interior back in, and my slicks/skinnies on the car, i should add 50 or so with new carpet and panels, and knock off 80 lbs for slicks/skinnies, that should put me at 3430lb race weight with 3/8 tank gas or so.
3450 with nitrous bottle
Next up is trying to gut weight from the car via fiberglass hood. I hope atleast 50lbs off the front end. Not sure what else i can get rid of without making it a pure race car
then the 12 bolt or 9 inch so thats alot more weight, plus C5 brakes up front should add a few more lbs
3300 lbs
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: 3300 lbs
I had my car weighed last week and weighed 3350 with full street trim and 1/4 tank of gas. The strange 12 bolt I put in this year only added around 20lbs, but it was in the rear, so thats ok
Re: 3300 lbs
Do you include yourself in the weight?
I had my stock trim IROC-Z on a set of electronic four corner scales.
LF 1014
RF 962
LR 865
RR 804
Total 3649 w/ 200 lb driver and full tank of fuel.
Includes all the options except the A/C.
( I'm hoping the plain jane Camaro I picked up this year will shave three or four hundred pounds.)
LF 1014
RF 962
LR 865
RR 804
Re: 3300 lbs
i got the car weighed at a truck stop... certified J-scales they called them. The CAT scales didnt read this time, but last time it did so idk what was up
no ac and cruise but cruise control doesnt weigh an ounce AC was 25-30 lbs.
Forzas are about 19-20 lbs while stock seats are 29 lbs each. I kept stock brackets including stock power seat driver side. that is a heavy bracket
No rear seats so i figure thats another 40 lbs or so..i didnt weigh those yet
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
Re: 3300 lbs
thats pretty light there man... when i raced i have no carpet, interior plastics, or console but both front seats. just guessin i figure with driver its around 3500 since the driver is almost 200lbs hehe
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
Re: 3300 lbs
I weighed my car at the track this past weekend. My car is pretty much loaded. I added padding for new carpet, leather interior, AC. Car has fiberglass hood, centerline telstar wheels. With me in it with small tool box in back it weighed 3526. I'm ~220. So 3306 without trying to reduce. But, it is a street car with no rollcage, heavier rear, etc.
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Re: 3300 lbs
My car comes in was at 3450 lbs with me in it and 1/4 tank of fuel. I just removed most of the rear bumper suport,installed an electric water pump and the track bar brace so I am looking for 3400lbs.I also have a turbo 400 trans and a 9'' rear.
Re: 3300 lbs
hehe, i weigh 3320 with an iron head sbc, full interior, roll bar, 9", and me in the car...and i weigh 290lbs!
Re: 3300 lbs
My question exactly.
I figured the IROC-Z's were about the heaviest of the 3rd gens.
What are the front and rear internal bumpers worth? Maybe 150 lbs combined. I always thought that would be a clever way to lose some weight.
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: 3300 lbs
hmmm..... i wonder what mine weighs.. its pretty much a stripped car with 2 seats, 10 point, power windows, steering and brakes.. has the steel hood, glass and ZQ8 wheels and tires.. plus 9", g-force t-5(about 20lbs heavier than stock), and the lakewood bellhousing (damn heavy thing compared to stocker)..
i would guess about 3100 without me.. maybe and 3300 with me.. i'll find out one day
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Re: 3300 lbs
Also with my car I have aluminum heads, no rear seats,factory front seats, and all stock plastic trim still in the car,carpet and sound deadner.I also have stock front K member and a 10 point cage.I have the front support still in but it is trimed to save a few pounds Also no HVAC or radio,speakers,and any wiring I could cut out. I also have a manual steering box and a glass hood.
Re: 3300 lbs
i'm running ACC replacement carpet up front, which is worth abunch cause it doens't have the big black matting on the back
no front bumper support (about 30lbs)
manual steering (another 25lbs)
no HVAC to speak of whatsoever, in the engine bay or otherwise
at the time of weigh-in i was running a mickey thompson et drag wheel with hoosier slicks out back, those weigh close to nothing.
'glass hood
fourthgen seats + thirdgen manual racks = superlightweight considering what they are
i don't have a radio in the car currently, nor the speakers.
gfx delete.
1le aluminum driveshaft
i think that's all the major stuff
'glass hood
gfx delete.
Re: 3300 lbs
My ACC front carpet and stock rear carpet weigh 33 lbs. panels/headliner/etc should add 10-20 more or so. So i'm about right on with 50lb estimate and i lose 80 with the wheels/tires in race trim. 24 lb nitrous bottle full, thats 3450 race weight....
I plan to get rid of steel hood, and thats about it Maybe tube k-member/a arms but that may not cut the weight.
I dont want a aluminum drive shaft since i probly will break it with the nitrous. Dont want to gut the gfx so thats probly some weight right there. And i'm not gutting power accessorys like seats/windows/locks
I guess 3450 minus 50 for a hood, bringing me to 3400 or so isnt to bad for a street/strip car
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
Re: 3300 lbs
My car is completely emptied out, interior, HVAC, P/S, empty steering column, no lights, no bumper insulation, no BS...& newly installed 10 pt cage.
I weighed in on a digital scale at the track & it came in at 3050 + me 200 lbs.
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Re: 3300 lbs
1982 Z28
It is 3300lbs with me in it
full interior with stock seats
10pt chromoly roll cage
all a/c and heater stuff taken out.
m/t wheels and tires
full 3.5" exhaust to the rear axle.
alum head sbc w/ th400
nos system
tubular k member and a arms
Here's a pic
nos system
Here's a pic
Re: 3300 lbs
Mine weights #3530 with me in it. Im #180. The only weight reduction measures were to remove the A/C box and heater core on the fire wall and no radio.
Car: Pair of 92 Z28s
Re: 3300 lbs
3180lbs without me.
3315 Race weight(I'm a light weight)
Iron block alum headed single plane carbed 355 with power steering
Tremec TKO 500
Complete Tubular suspension
No rear crash bumper/bar
Alum Front Bumper
Full Interior/Stereo/Sub(22 lbs)
No A/C or Heat, no box/controls all the vents were removed only a gutted dash with Head Unit and Gauges
Lightweight Carpet, No padding underneath
4th gen front seats, No Rear Seats, 4th Gen belts(3lbs total saving vs 3rd gen belts)
Fiberglass Hood
50lb Rollbar
Large 13.5" rotors with 4 piston Brembos in front
Z06 17x9.5" front 18x10.5" rear
10 Bolt with disc rear
3" Duals with turndowns at axle
My car was pretty light for what it was, if it was a pure drag car i could definitely get it under 3000lbs.
Tremec TKO 500
Alum Front Bumper
Fiberglass Hood
50lb Rollbar
Car: 1988 Camaro
Engine: 383 Stroker
Re: 3300 lbs
How much of a weight difference is it from going from the stock iroc hood to lets say a cervinis glass hood?
Re: 3300 lbs
geez all you guys are pigs, lol My car w/o me (185lbs) and half a tank of gas is 2900 flat by flying j's scales. I had a slip to prove it but my kids decided to use it for a coloring book. My plan is for a 2800 pound car with me in it. It will take some work but I can do it.
Re: 3300 lbs
just wait till you're fast enough to require a roll-bar and the choice is either install one or don't come back to the track...that added 80-120lbs is tough to get around when you're still wanting to keep all you're interior. or when you need to upgrade to a real rear cause rebuilding 10 bolts just isn't making sense any more...those are real weight issues that can't keep the car light anymore no matter what you try
my goal is a little more realistic, though i havce a solid 100lbs over you just on my person, but i'd like to have a ride that'll run into the 10's with full interior and weigh 3200lbs with me in the car...and still be able to drive up to a cruise-in or to school or to whatever else might peak my interest.
1 Post
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Re: 3300 lbs
According to the scales at the track that they use for the Sotck Super/Stock classes.....2910 with me in the car. (175#)
8pt cage
VFN lift off hood
TH400
Iron Headed SBC
and enough interior for me to do what I need to do behind the wheel.
Looking to get to 2800 with me in the car by spring.
Planning to remove crash bars from the doors, lexan windshield, mini-starter, lexan T-tops, and possibly changing to Wilwood front brakes
8pt cage
VFN lift off hood
TH400
Iron Headed SBC
Re: 3300 lbs
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: 3300 lbs
Last time I weighed mine it was upper 3600's w/ me at 150lbs, used to be 3300 when I was doing mid-upper 11's. No blower motor, air pump, or washer reservoir, manual brakes and steering, cut up front bumper w/o plastic, mini starter, aluminum heads, th400 and wheels and tires were slightly lighter than stock. Strange 60 axle added 80lbs, 3" steel DS, beefy trans mount and tq arm, 6-point soon to be 10, SFC, and the Procharger/intercooler is probably another 80lbs up front. Probably getting heavier with the big turbo and w/a intercooler I'm planning, but more towards the rear.
Re: 3300 lbs
last time at the track, 3305, no interior except race seat and dash, aluminum headed factory roller, lots of stuff taken off, need to take about 1k off it, then it will be fun !
1 Post
Car: 1991 Z28
Engine: 400 ci LS3
Transmission: Jerico DR4
Re: 3300 lbs
Factory 1991 Z28 305/5 speed - air delete car (RPO C41) = 3280 lbs w/o driver. Same car with aluminum headed SBC, Moser 9" w/ back brace, and an 8 pt now weighs 3360 w/o driver. Weighed both times at the same Cat truck stop scale. I have no idea how accurate these scales are but they claim to be "certified".
