ford 9"
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
ford 9"
i ordered a shortened (sp?) 9" housing when i ordered my 4 link kit but one thing i know nothing about is rear ends. i know i need a center section and axles but i forgot to ask what kind if any housing ends are on it for the brakes and it will be here in the next day or so so its to late for it to matter but other than what goes inside of a 9" i know axle bearings are in it somewhere im guessing near the housing ends but what else? do any of yall know of a schematic or something online the shows the parts of a 9"? (sorry if this doesnt make sense but sometimes it hard for me to explain what im trying to say on a computer)
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: ford 9"
you`ll need a center section (complete..includes pinion yoke,bearing, ring + pinion, some sort of carrier i.e posi, locker, spool) You`ll need axles and bearings which are pressed onto the axle shafts..called green bearings. you`ll also need bearing retainers, some sort of brake package.
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Re: ford 9"
If the housing has ends already welded on then your 4 link brakets will have to be cut to be installed. Just make sure they are welded on per the directions that come with them, or the pinion angle will be dificult to get and still have all the bars the same length. If you are doing the welding yourself go from side to side without getting too much heat into the tubes as it will warp them.
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
Re: ford 9"
hey greezemonkey whats goin on bud, i havent talked to you in forever. how is your car going? still pouring money into mine like im sure u r yours. hopefully itll be soon within a year or so. im going a little deeper than i had planned on so its taking longer. plus im broke so that doesnt help any lol. thanxs for the replies guys. i tried to find something online about 9" assembly but couldnt find a darn thing.
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
Re: ford 9"
geez greeze talk about bookin it, thats awesome. and hey man i still cant thank you enough for all the help u have given me in the past although maybe its ur fault i got my head so deep in the "little" project. lol its good to see ur still kickin around in here i thought u had gone.
