New best 60' and e.t./mph
Car: 84 Berlinetta
Engine: 360
Transmission: 350 turbo
Axle/Gears: 9"/4.11
Went this past saturday to the strip, made couple of runs my previous best was 11.55 @ 117 1.64 60'. I recently purchased a carb from PROSYSTEMS off the trailer my car ran an 11.31 @ 119.11 my second pass was a new best of 11.26 @ 119.20 best 60' 1.56.My new best was with a smaller carb 750cfm my old one was a 830 holley hp. Race weight 3050 footbraking, 360 small block victor jr/ iron headed world product heads, flattop pistons,10:1 cmpr.,solid flat tappet comp cams, mechanical fuel pump, mech water pump, and hi performance stock appearing distributor, stock location suspension car: umi lowers/subframe connectors and spohn torque arm, f-41 stock shocks/springs
ford 9'' 4.11 gear 28/10/15 hoosier slick
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: New best 60' and e.t./mph
that's crazy good times. what are the cam specs ?
is that a TH350 in that?
you run that on just premium pump gas? is it a street legal car still?
Car: 84 Berlinetta
Engine: 360
Axle/Gears: 9"/4.11
its mix 1/2 pump gas 1/2 108 race fuel, yes its a th350, 260/260 @ 106 lsa 1.6 rocker and it is street legal but im running slicks!!! yes hatsoff to the guys @ PROSYSTEMS that is a bad to the bone carb with hardly any tunning.
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
congrats. Our combos are quite similar (cept I'm heavier, more compression, and a 110LSA cam) I hope I can get those kind of times out my car very soon... If not I'm just going to fill the bottle and start spraying it.
I've talked to Patrick at PRO Systems a few times and he is always quick to answer, friendly, and seems quite knowledgeable. I might just buy one of their carbs when I get the cash.
![lmao](https://www.thirdgen.org/forums/images/smilies/lmao.gif)
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3:73
![thumbs up](https://www.thirdgen.org/forums/images/smilies/thumbsup.gif)
Car: 84 Berlinetta
Engine: 360
Axle/Gears: 9"/4.11
went last night to the racetrack and improved again, note that I replaced my stock water pump and bought an electric water pump and the air temperature was 42 degrees about 20 degrees colder than last months run improved a tenth and close to a whole 1 mph little blurry hope you can read the time slip
Car: 84 Berlinetta
Engine: 360
Axle/Gears: 9"/4.11
no frnt/rear reinforcement bumpers gutted out the dash so no a/c no heater, fiberglass hood and good weight saving on wildwood rear drag brakes instead of the junk heavy rear drums
