1/4 mile estimates
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
1/4 mile estimates
hey guys im woundering what my ride will do in 1/4 with this set up
i will have an 89 formy 350(not l98) but TPI
edelbrock headers
edelbrock tpi intake
Nos 150 shot(will spay)
3.73 gears
Slicks
edelbrock headers
3.73 gears
Slicks
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: 1/4 mile estimates
dont have a time thought of but video it cause i want to see if ur rear holds those 10 bolts dont like slicks......
Car: 89 Formy
Transmission: A4
yea i just had it rebuilt and i will be leaving off idle...since i dont have a stall converter..but owell lol
Car: 1991 Z28 - 2000 Z28
Engine: L98 - LS4
Transmission: 700R4 - 4L60E
Axle/Gears: 3.23's - 3.73's
Hard to tell, but I'll say high 12's... hope you prove me wrong and do better. As for slicks and a 10 bolt... just make sure it doesn't wheel hop. I still have a 10 bolt in my 2000, and it's hanging in there. Stock axles, posi, etc. I just have the axle tubes tack welded and a MAC girdle cover. The car is no light weight, and has enough nuts w/o nitrous to run the time in my sig.
Just the same, do like I did and piece together a spare rear for back up. I expect to get about a seasons worth of racing before mine goes boom.
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
What heads and cam?If it were a L98 i`d say mid 12`s on the bottle for a guess.Atleast I`ve seen other stocl L98 run in the 12`s on 125 shot.Your sig says something about 260 hp 350.If your talking about the gm crate 260 hp 350 i`ve heard several not so good things about them.Most of all being a pretty serious downgrade from the L98.
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
When I had my edelbrock headers heads and zz9 cam with stall converter I was running 14.2-14.1's. You would prob run 14.5's na and with spray around 13.3-13.5 range. The big prob for you would be getting out of the hold with the stock rear and slicks. Are you going to spray off the line? If you had a higher stall converter you would may dip into the 12's. Let us know how it goes
1 Post
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
3.73's would be a lot of gear for a near stock TPI car, I assume the Edelbrock intake will pull beyond where stock TPI dies, but its still gonna be breathless in 3rd at the end of the track unless its been upgraded to a decent cam and heads.
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Joe blue I would think you`d be running better times than that with those heads and cam on a 383.Your 60` looks great but My car ran 8.7 1/8th with stock stall and 2.73 gears on a much milder 350.No 1/4 tracks anywhere around here but my 8th time should net me mid high 13`s.That was before a stall and gear change.You said you were running low 14`s with zz9 cam and headers.people are running high 12`s with 350 and 305`s.Is that at high altitude or something
Car: 1988 Camaro
Engine: 383 Stroker
That was all that was done to the car, headers cam and edelbrock heads. the car ran 14.8 bone stock. With those improvements it ran 14.1-14.2. Within reason. I don't know many 305 n/a running 12's, but I know there are some on this board
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Thats what I`m saying,better heads,cam and headers than I` m running.Mines all production stuff other than the flowjunk headers.What was your 8th time.And no offense but 12.53 seems alittle slow for a miniramed 383 with all you have done to it.Large valved heads and all.Faster than my car for sure,but that sounds like it should be more in the low low 12`s to me.Seems like it `s got more in it.Who tuned it?TPIS?
86CamaroDan
09-29-2015 10:08 PM
