what mph do i need>???
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Im lookin to go 9.90's out of my car. its going to be gutted down to a total of 3,000 pounds. im lookin at getting 1.3 60' times. i know i need high 130's. but im not sure how much a better 60' can help an et at that time.
Also does anyone know what our cars weigh stock?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: what mph do i need>???
Depends on the options originally in the car. Typically, it's around 3500 pounds but can go a couple of hundred pounds either way.
Trouble with going faster is that you also need to add weight. Dipping into the 9's means things like a full cage which can easily add 100+ pounds back into the car.
My car is a stripped down, race only car and the race weight sitting on the starting line is 3042 pounds. It's getting difficult or expensive to get that lower.
With a race weight of 3000 pounds (car, driver, fuel etc) and running 9.90, you'll need to put approximately 675 HP to the wheels. That means you'll need about 800 flywheel HP. You're going to need a lot more engine or a lot more power adder to do that with a SBC.
Car: 85z28
Engine: sbc
Transmission: th400
Axle/Gears: 3.80 gear 35 spline axles
my car is a pump gas 355 with a 200 horse kit and it weighs 3320 with me in it runs 9.74 @139.90 with 1.301 60 ft and there is no stock rear suspension everything is bolt in aftermarket.The car has a BMR torque arm, Wolf anti roll bar, wolfe lower control arms and adjustable pan hard bar.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
87 TA went 10.07 at 133 in a what i think was a 3400 lbs car, not sure if that was with him in it or not. probly 600whp or so. his 406 was probly in the 450whp range n/a. 125 shot puts close to 600whp. my car is closer to 3500 lb race weight anymore and i trapped 125 on a weak 150 shot that probly acted like a 100 shot so thats 500whp or so. I expect 128mph with the leaner jetting and that should be in the 530-550whp range. made 400 on motor alone and go 118.
9.90's consistantly in a 3000-3100 lb car should take 135-137 mph traps or so depending on the launch and how the power band/gearing is, and that should be around 550-600whp i'd say
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
well I'm trapping 116-117 and I have large kit on my car
I'm in the process of a tubular front end and full suspension
Also I'm swapping out a bigger can to get me in the 135-139 region
I was just curious if that and a great launch could get me a 9 sec pass
if the car can pull 1.3x or at least a low 1.4 60' i guess its possible....
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
lol i was thinking 175-200. itll be a nitrous cam and single plane intake makes nitrous feel so much better
Car: 89 Iroc-z
Transmission: TH400
it will be a stretch to reach 135+ mph with that setup i think. I know i've seen cars trapping 124-125 on motor hit 133 with a 125 pill, i think you need to be closer to 120 on motor and then add the 200 shot to see it go near 135.
I hope my nitrous 150 shot acts like a true 150 shot now that its leaned out where it needs to be, but i still only expect 128 mph traps from my 118 on motor.
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
My old 380'' motor would go 120mph on motor and with a 275 tune up it would go 9.70 @ 140mph with a 1.40 60 ft. @ 3400lbs. To make a 9 sec pass you will need to be 133-136 mph range
darwinprice
17
10-11-2015 11:51 PM
