stock driveshaft
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
stock driveshaft
hey guys, assuming the u joints are replaced with decent high strength units, how fast have you gone with it? anybody playing russian roullete with a transbrake on the stock ds? just trying to plan my build for the winter
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: stock driveshaft
The factory 3R u-joints are quite strong if well maintained. I think the 3R is similar in strength to a 1330. Not as good as the 1350 which is preferred for racing but still strong enough for most street cars.
Using transbrake on my factory steel, best 60 ft 1.31... Also used the fatory aluminum on my TA, 1.38 best 60 ft on that with footbrake.
Car: 1987 IROC
Engine: 350 vortec
hey guys thanks for all the replies, and i think all you guys are running about where my goal is (mid-low 9s) TGO rocks
Car: 87 IROC L98
If you plan on running that quick, invest in a better driveshaft anyway. You'll probably need a custom length driveshaft after replacing the entire driveline.
3" x .083" wall steel shaft with 1350 u-joints and yokes.
Car: 1987 IROC
Engine: 350 vortec
It's in the plan, just trying to prioritize where the money is going. won't be going quite that fast till late in the year next year i'd bet, i still don't have a power plant
ambainb
04-25-2016 09:21 PM
Genopsyde
10-07-2015 08:35 PM
theshackle
08-23-2015 03:49 PM
