First time to the strip, times and setup how can i improve?
best
60 ft. 1.832
et 12.632
mph106.89
car was consistent
406
9.8 cr
edelbrock rpm heads (170 cc, 2.02 1.6)
air gap
750 demon (stock jets, should I jet up?)
1 3/4 headers, 4" mufflex (spintech)
cam crane h288-2 (113821)
hydraulic flat tappet
226/234
.458/.473
Nitto drag radials
completely stock suspension
3.73 posi
2800 stall
i also didnt run faster with the converter locked up? but thats not a problem anymore cause my 700 lost od
60 ft. 1.832
et 12.632
mph106.89
car was consistent
406
9.8 cr
air gap
226/234
.458/.473
Nitto drag radials
3.73 posi
2800 stall
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: First time to the strip, times and setup how can i improve?
A couple things I noticed, the edelbrock heads don't flow worth a crap. I had those same ones. That cam is very small, and a little more stall in the converter. When your at the track do you remove the front sway bar?
? i think some more stall is a good idea since im gonna have to swap the trans soon. What kind of gains do you see in your 60ft/et with a disconnected sway bar?
Car: 1988 Camaro
Engine: 383 Stroker
My car works great on the streets, and get 21 mpg when i baby it
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
What altitude are you at?
i talked to my engine builder today and we came to the conclusion that the trans was done/getting worse seeing as my first run was the best. I am pretty set on a tko600 which means my setup can be extremely streetable, my altitude was 550 feet, it was 95 degrees and humid as hell.
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
you'd need a cam with more lift id say or you could try some 1.6 rocker arms. other than that a 12.6 is pretty good id say. did u hook up? For carb jetting do the primaries by plug color and jet the secondaries for maximum MPH (not et) keep going up on the secondary jets until the MPH stops improving then go back a step
evilstuie
01-09-2020 08:29 PM
