PREDICTIONS FOR TONGIHT
well lets have them heres the fast et slip
keep in mind on a slower run 14.0 the car was .300 slower out of the hole and dam near ,600 slower at the 1/8th mile and up 7 mph @ the 1/8th compared to that slip
edit
i quess i should write in here why the mph and time was way down on the above slip, i had dbled my injector sizing and only changed the fuel injector cconstant in my engine management system. thinking they would flow as linier as the old smaller injectors and this was not the case. the fuel map needed alot of tweaking.
the above slip was also run with only 10* of ign timming inthe motor
end edit
the only changes being made to the car for tongiht are
#1 slicks
#2 full boost launches (7psi) instead of 2-3 psi on street tires
#3 the fuel map has benn fixed and im adding 6* of timing to the motor for a total of 16*
let the speculations begin
il post the results up tongiht when i get back home lets see how close u guys can get
and just for ***** and giggles im going to make my final pass a 15psi run any queses on the et for that run?
edit
end edit
#1 slicks
BlownBird
10-24-2003 09:30 AM
