few 100 shot passes
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
few 100 shot passes
weather was THE WORST ive ever raced in. it was bad.
motor pull was only 7.03 at 97.82..... it felt so slow i thought some plug wires were off.
1st pass on the spray was 6.76 at 105, with a horrible 1.62 60ft.
6.64 at 104, 6.59 at 105, still with only a 1.53 60ft. motor it does 1.50's so i adjusted the shocks on full looose front and rear, and took out about a 1/2 pound of fuel pressure out.
1.402 60ft
4.192
6.095
6.522
105.38 mph
275/60 hoosier DR's on a 8" wheel
talk about fast..... car was in the air.
with a better track, i dunno what its gonna do on a 150..... not to mention cooler weather.
motor is a stock 6.0 with a 235/237 cam. e water pump, long tubes, full catback.
1.402 60ft
4.192
6.095
6.522
105.38 mph
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Re: few 100 shot passes
congrats, makes me feel good about the 6.0 i want to build over the winter, but mine will have L92 heads and probably a cam with a little more duration split. how much stall do you have in there? and what's you race weight?
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
its a yank 5000 stall, 4.33 gear. raceweight is 3400 pounds, give or take 20 from the scale. i have not been on a set of 4 corner scales, but i need to.
Car: 1987 IROC
Engine: 350 vortec
i may be doing a 200 shot in a fogger but the L92's an TSP 233/239 look like a pretty good combo. The CNC ported L92 heads look like the way to go though. i would like to run 6.0 in the eighth to be well, kind of competitive in the 10.5 heads up class we have been running at my home track. my race weight will be between 3050 and 3150 i hope.
sailtexas186548
02-17-2017 03:07 PM
Doobie52
09-11-2015 06:19 PM
