Adjustable Coilovers
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
Anybody running adjustable or double adjustable coilovers in the rear?
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: Adjustable Coilovers
I put a set in last winter and just today had a chance to see how they work, I made two passes this afternoon on the 7 setting of the single QA1`s and it chattered the tires and slipped and slided thru the first 300 ft. Dropped the shocks down to 5 and just like that- dead straight dead hooks the rest of the afternoon, I`m using 12 130 pound springs on them too.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Comp Engineering 12 way singles here. QA1 12" springs rated at 110 pounds. Still playing with the settings. Have tried 1-3 so far on a very slick track. May stiffen them up next time.
What are the part #'s, I just started looking for them & cant seem to find them. I guess I could all Jegs
Car: 87 IROC L98
This is the coilover shock that I use. $215 each
http://www.jegs.com/i/Competition%20.../2770/10002/-1
You need to get the front and rear weight of the car before you can select a spring. You'll also need shock mounts. These are not direct replacements for the factory shocks.
darwinprice
17
10-11-2015 11:51 PM
LT1Formula
10-08-2015 08:34 PM
