Whos the fastest 3rdgen w/ Fuel Injection?
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
Looks like alot of fast cars w/ carbs, but who's running low ET's w/ Fuel Injection?
Me???
12.2 @ 105 -1.65 60'
Factory 5.7L w/ Factory TPI & N2o
Me???
Car: 1990 IROC-Z Camaro
Axle/Gears: 10 bolt
Re: Whos the fastest 3rdgen w/ Fuel Injection?
11.62 @ 117 355 sbc TPI on 125 shot. I hope to run mid-low 10's with a 406 TPiS, Miniram, and a 200 shot.
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I've got a 9.94@ 137, and there's another couple tenths left in traction and weight.
I just got my MiniRam & 406 is being built as we speak. Good to see FI still running strong. I was just seeing alot of 3gens converted to carb. Just wanted to make sure I was going in the right direction.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
406 mini rammed, 10.87 best N/A, 10.0 best 150 shot..
Pump gas for both best. Engine now resides in my 94 with same efi set-up.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I run fuel injection but it's not EFI. I run a mechanical alcohol injection system. Ron's flying toilet(s).
www.ronsfuel.com
www.killerrons.com
www.ronsfuel.com
www.killerrons.com
11.50's at 119 here for now... it will do 11.3's once i can hook at full launch and get some more gear. cool air it should touch 120-121 mph and 11.2's i hope. It SHOULD be doing 11.4's right now but i cant get it to 60 foot any better than 1.59 it seems. When i did go 1.55 i had other top end problems which killed the run.
just a streetable natural aspirated 383 on 93 oct pump gas
FULL bolt on L98 last year n/a went 12.95 at 103.8
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Car: 1987 IROCZ
Engine: aluminum 400
Transmission: t56
Axle/Gears: IRS out of a 2000 corvette
i run low 10's on all motor out of a small block with speed density TPI
Car: 1987 IROCZ
Transmission: t56
i have fiberglass hood front bumper, front fenders, doors, side skirts, rear bumper, decklid, lexan side windows, lexan rear decklid. a all aluminum brodix small block and ik210 brodix heads, aftermarket ported and polished edelbrock intake and runner. aftermarket fuel injection. full 2000 corvette rear end, air locker, and 10 point roll cage. stripped interior with custom fibergalss dash, racing seats, fuel cell, full custom true dual three inch exhaust. mickey thompson et drag radials in the back, mini tubs. custom dual air intake. i haven't lost to any car on the street yet. and i still run 93 octane pump gas. and it is my daily driver. tubular k member from spohn. tubular upper and lower control arms. tublar spindles from wilwood with all wilwood brakes on all four corners. haven't ran it at the track but it eats 25psi fully built stripped hondas. and alot of old muscle cars.
Car: 87 IROC L98
Get a timeslip before making an ET claim.
Car: 1987 IROCZ
Transmission: t56
why don't you drive here and i'll show you on the street. anyone can make there car hook at the track and go in a straight line but try to hook it on the street and take a corner. and then you can tell me about how fast you are.
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
I bet that is one cold ride up in Minnesota with those plex glass windows and all. How are those drag radials treating you on your commute to work in the winter? Post some pics of your ride we all like to look at fast cars.
DUDE thats freaking AWEEEEEEEEESOMEEEEEEEEEE i wanna see some pics! that like my dream car that i thought only existed in my head, full independent rear from a c5/1 did you have to narrow the axle? and aluminum small block, if its gen one that s freaking cool to. PICS PICS PICS!!
trbo355 went 9.4's on a 350, truck heads, LTR tuned port, xe268h cam, th400, 3.00 9" and I must be forgetting something, oh yeah. Two TE-64 turbos running 25psi and a 100shot.
He's running Holley Commander 950 EFI.
![doh](https://www.thirdgen.org/forums/images/smilies/doh.gif)
Car: '82 Z28
Seems like only the slow people say that everyone can hook at the track and go straight.
not only that, anybody who says "straight line" obviously hasn't been in a fast car on a small tire...especially on the street. As for taking a corner
![Roll Eyes (Sarcastic)](https://www.thirdgen.org/forums/images/smilies/rolleyes.gif)
![nod](https://www.thirdgen.org/forums/images/smilies/nod.gif)
what i wanna know is how a 20 y/o that works at NAPA can afford a brodix aluminum block. then after saving up the money to actually by one, he decides its a good idea to daily drive on one IN THE NORTH! does this just not make sense to anyone else? i'm calling BS on this one. i say post up pics of this all fiberglass (not sure why you would go to all the trouble, have you ever actually lifted a fender from one of these cars? not exactly heavy sheetmetal there) IRS suspended, aluminum 440cubic inch tpi monster (like a ported edlebroke junk tpi intake will actually feed that many cubes
Car: 1987 IROCZ
Transmission: t56
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Thats great know lets see some pics!!!
At your pay rate im shure you have other projects in the workings.
Glad to see the younger people out doing things and not just sitting at home spreading crap all over the internet kudos to you.
Engine: L98 355
Axle/Gears: 3.70
Currently N/A went 12.8@104, highest mph 107 355 TPI full interior no weight-saving mods. And that was manually shifting my 700r4, my shift points aren't anywhere near optimal at the moment.
My goal with my build is to go as fast as I can on a 355 TPI using only mildy ported aftermarket parts N/A...nothing radical like some of the guys on the TPI board are doing, simply because I don't have the knowledge or access to the machinery to get 300+cfm out of an intake base. I know I've got more in my current setup now, and it's nowhere near optimal with my crappy headers, stock ported base and 48mm TB...plus I'm not running a whole lot of compression.
When I started this project I was told I'd be lucky to break 13.0s. I'm well into the 12s and with a few better parts hope to be in the low 12s...and from what I've seen locally and on this board, that's 383/AFR195 territory. Not too bad from a little 355 and 180cc heads.
Car: 1987 IROCZ
Transmission: t56
i'll get some pics as fast as i can for you.
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
400IRS, where exactly are you in MN? Im in Glencoe, just west of the cities and id like to see your car in person if it is what you say it is.
Car: 1987 IROCZ
Transmission: t56
down by roch actually 10 minutes from nelson wisconsin. in a little town called theilman. their is only 36 people that live there. but i do work at napa in rochester.
Car: 91 Formula
Engine: 383 HSR
Transmission: 5th 700R4
Axle/Gears: 3.89
I was just reading over this post and was wondering how many of you have upper control arms on your car? Maybe it's just to add some weight? I also call BS until I see a time slip and some pics of the car. My junk runs a best of 12.7 @ 107 Need stall and better rear suspension I think my mods are in my sig.
Maybe now my sig will show up.
Last edited by 91RamAir Formula; 08-27-2008 at 03:37 PM. Reason: Automerged Doublepost
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
I would really like to see pics also. I have pretty extensive mods on mine but honestly don't know what it can actually do. I make alot more than you do at NAPA and can't afford all the mods listed. And as far a never been beat on the street. In the town of 36 people, you must not have too many fast cars in that area. We have several cars in this area well over 1000hp and closer to 2000HP and with twin turbo's that has never been beat and looking to race. Bring your title. The only way I can keep up would be if I had a chain from my front bumper to their rear bumper.
http://www.460ford.com/viewtopic.php...ghlight=falcon
He drives this around quite a bit but it is not his daily driver. Without time slips and pics, it's hard for people to believe.
ah new york street racers lol, there are alot of BAD cars up there, and crazy dudes that will line them up anywhere any time.
I would like to say I am a third genaration engine builder too (hey thats a pun....) my dad built engines, my grandfather built engines, and buildings lol
but seriously, claming a time without a slip is well kinda lame, and then comparing to rice...well that would go here
https://www.thirdgen.org/forums/theo...street-racing/
#42
Car: 82 camaro
Engine: 434 ci
Transmission: t400
He had a great start with he's eleven posts but no pics.
![bs](https://www.thirdgen.org/forums/images/smilies/bs.gif)
#44
Car: '82 Z28
Last Activity: Today 09:29 AM
I don't see any pics though. Yet another case of someone trying to impress people with lies.
#46
just got back from my builder & I got to see all the parts before it gets put together. Balanced Scat crank, balanced H beam 4340, even balanced pop up pistons, (within 1 gram). Cam to be announced.
w/ new brodix heads should come out to about 13.5-14 to 1 C/R.
Later today I called & checked on an Acell DFI, w/ custom harness, w/ wideband o2 & thats when I found out that my computer might cost about the same as my engine, ($3000)?????
Any other ideas or thoughts on computers ( i know, diff topic/board)
#48
Give this guy a call. This is who I bought mine from.
Rob @ Force Fuel Injection
305-235-6160
Be careful, he WILL talk your ear off. And tell him "Local Dave" referred you.
#49
