Help
Car: 89 formula
Engine: 406
Transmission: th-350
Axle/Gears: 456
Help
Does anybody know how big of a slick you can stuff under a stock wheel well on an 89 formula?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Help
Without any modifications, I know a 28x9 will fit with no problems. I stuffed a 29.5 x 10.5 under my fenders with some inner fender modifications.
My car is back halved now with 32 x 14
Re: Help
is that stock wheel well with no other work, or what will fit with further ...adjusting? you can fit a 28-10.5 w under it but you will need to remove the bump stop brackets and do a little massageing, I think that a 325/50 15 drag radial will fit with the same mods, but less chance of rubbing at speed since they do not grow like slicks do
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: Help
my tire measures out to 28.5x11.50 DOT slick or 28.5x10 slick..
all on a 15x8 with 4.5" bs.. only mods were barely any BFH clearancing..
