12.7 at 107 with 305
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
so i went to the track friday night to see how my new carb setup would run, its a wieand stealth manifold, 650 dp holley, hooker 2210s and true duals with moroso mufflers, first pass
-.248
1.793
5.310
8.210
84.49
10.719
12.827
107.44
second pass
.045
1.740
5.243
8.147
84.19
10.663
12.775
107.34
im putting a single plane high rise manifold on it tonite and hopefully going back up on wednesday to run again, also i this is completley untuned i havent as much as adjusted the timing since i got it to fire a few weeks ago, and the carb is off of a low 11 second nova that weighed 3250, im hopeing for a 12.5 with the high rise, then low 12s when i get it tuned then im putting the 150 shot back on and hopeing for low 11s
last year my best was a 12.95 at 105 i believe
and my suspension consist of v6 springs with a bag on the right and 50/50 comp shocks edelbrock panhard bar, lakewood lower control arms, spohn torque arm, lcarb, moroso trick springs and 90/10 struts, and no front swaybar
the suspension worked perfect it yanked both front wheels up about 6 inches with only a 1.7 60ft
-.248
1.793
5.310
8.210
84.49
10.719
12.827
107.44
second pass
.045
1.740
5.243
8.147
84.19
10.663
12.775
107.34
Re: 12.7 at 107 with 305
Nice....!
Originally Posted by 89305formula
im hopeing for a 12.5 with the high rise, then low 12s when i get it tuned then im putting the 150 shot back on and hopeing for low 11s....
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
excellent! there's alot to be had in tuning, not only engine but suspension too.
Car: 89 formula
Engine: 305tpi
Transmission: t-56
yea i hope to have the car on a dyno by the end of the month to have it tuned, im not really sure what the car weighs but its a fully loaded formula with some weight reduction under the hood and a glass hood
[quote=89305formula;3792691]so i went to the track friday night to see how my new carb setup would run, its a wieand stealth manifold, 650 dp holley, hooker 2210s and true duals with moroso mufflers,
first pass
12.827
107.44
second pass
12.775
107.34
What else have you done to the motor, heads, cam, or whatever?
first pass
12.827
107.44
second pass
12.775
107.34
Thanks, I am new here and I am not familiar how the system is set up. I thought that you had a second car with these items in it. Sorry
Sorry I am new and I did not understand the system setup. I thought that you had a second car with those items.
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
what cc runners are those pro comps, are they the CNC version, and are they with the stock springs/valves? I heard mixed things about these heads.
Car: 89 formula
Engine: 305tpi
Transmission: t-56
i belive there 180cc but im not completley sure, the springs are the ones that came in my cam kit from comp, no there not the cnc version, ive also heard alot of things about these heads and most of the things i heard were bad, they seem to work good for me but im still considering putting a set of ported 416s that i have at my shop and see if there is a difference in power
