1/4 time?
Car: 89 Formula
Engine: LB9 TPI
Axle/Gears: 3.73(coming soon)
1/4 time?
its an 89 formula 305 TPI,700r4
my mods are hedman headers with y pipe
K&n filter
desreened MAF
comp cams 262
.210/ .220 /.480/.480 112 lsa
computer tuned for camshaft
et streets
K&n filter
desreened MAF
comp cams 262
et streets
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Re: 1/4 time?
what are your eighth mile times? that will give me a better idea, sounds like your setup is similar to mine only i have the gears. Gonna venture out a ways on the limb and say 14.78. rough guesstimate.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: 1/4 time?
honestly, with those mods and a good converter/gears, you could make that car a nice little runner, but with stock converter/gears, you'll be slow.
also, look into what is available for the tpi intakes, there's some nice stuff out there that'll help that camshaft reach it's full potential.
Re: 1/4 time?
Im with mw on thegears and converter.The car will be slow with the stock stuff. You need around a 3000 stall and 373s and thecar will go low 14s high 13s. I did it when mine was a 305.
evilstuie
01-09-2020 08:29 PM
Street Lethal
04-30-2019 12:14 PM
