what kinda power with this:"
Car: 84 camaro
Engine: 72 chevy 406 sbc
Axle/Gears: 3.42 eaton posi
i got a early 70s 400 sb chevy dont know much about it except what ive done,i hade crank turned 20 new bearings,doubleroller timing chain,sounds like it has a small cam maybe rv slight lope in idle,no idea if heads had any work lets say they are stock? performer intake edelbrock 4 brl carb,headman shorty headers&y pipe hollow cat and flowmaster muffler,3.42 gears its in a sport coup 84 camaro with built 700r4 trans what you all think hp is around and 1/4 time estimate? thanks for any replys
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Re: what kinda power with this:"
with no limited slip? dunno ab that
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
14s, those heads are junk. smogger 70s 400 heads are good for door stops though. grab an XE274 cam and vortec heads with a performer rpm air gap, or some dart iron eagle 200cc heads and run with them. Would probably pick up 80hp easily.
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
I wouldn't be building too much power running a stock GM 400 crank. Seen lots of them busted. My brother built a 400 a couple of years ago, crank only lasted 50 to 60 passes. He got disgusted and gave me the engine. I'm putting it back together with a eagle crank and 13.7/1 forged pistons. Hope it lasts longer for me. It was a balanced assy too.
Car: 1984 Z28
vortec heads are $260 new each or $550 for the sdpc modified ones. grab an intake for $150, sell off your old heads and intake and you'd be rocking.
Car: 84 camaro
ok,those heads complete ready to bolt on? for 550
and then with the heads you mentioned and the cam and intake ,whats your best guess on horse power with the rest of motor?and is THAT enough for 12s in the quarter?
Car: 1984 Z28
for $550 they are bolt on and go. you will need centerbolt valve covers, which the stocker tins are $26 for the pair from that scoggin-dickey parts center SDPC place as well. With those heads, XE274 cam and performer rpm air-gap vortec intake you are looking at 12.20s easily with a 3500 stall and 3.73 posi with 26" slicks. Some have dipped into the 11.90s with this same combo as well. Just remember with a flat tappet cam to run rotella shell oil so that it doesn't eat the cam. I ran 15w40 oil with a similar type cam.
Car: 84 camaro
ok, thanks for your help AGAIN steve,im printing this now lol
whats your horse power guess on that?
Last edited by one wheel peel; 06-04-2008 at 01:39 PM. Reason: Automerged Doublepost
Car: 1984 Z28
should be 420-ish on a 406 engine. probably similar torque numbers.
sailtexas186548
08-24-2015 10:11 PM
