new best 8.090@85.04 in the 1/8mi
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
new best with long tube headers and carb work. now i have to buy a power valve.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Re: new best 8.090@85.04 in the 1/8mi
wow thats moving man! well into the 12's. i was 8.22 i think when i ran 12.95
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
nice dude!! im barely in front of you with a 7.9 at same mph...i think im running pretty fat though...all my spark plugs look rough....and they arent even a year old!!
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
good gawd! you guys all must be doing some impressive launching. ive gotten 7.9 in the 1/8 but at 91mph. at the end of the quarter it does 12.2 at 116
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
your getting there! my best with the 305 is a 7.81 @ 86mph
Engine: 7.0L
what's your timing set at? do you have it locked out yet so there's no mechanical advance? i found 60' in that and some tuning.
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
Very nice!
I went 7.8 in the 1/8th and 12.3 in the 1/4.
thanks guys. i got the a power valve in. ready to go to the track this friday and see what it run in the 1/4. anyone have idea what itll run lol had to ask
Engine: 7.0L
set it to where it has 42* total timing...i bet money that'll wake it up some! just take your timing gun to the track and make one pass like that (after you make a couple of passes with the new powervalve in the car to get a good baseline)
i keep the timing light in the car.when does it all need to come in by it comes in now all at 2500
Engine: 7.0L
that's fine...which means that it's all in when you flash the converter, which is good. you want it to all come in on the launch...that's why so many folks lock out the mechanical advance, that means that all the timing is in all the time. mine is locked out at 42* all the time.
Car: 89 Iroc-z
Transmission: TH400
42 seems high. with trick flow heads, he probly has good combustion chambers and it should like less total timing but you cant hurt anything by trying the timing mods. just my thoughts
Engine: 7.0L
good point, i hadn't thought about that...i know my 305 with the 416's likes 42* and my dad's 350 with 200cc iron eagles also likes 42*, so i figured i'd share with him what my experience has shown me.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
42deg seems like a lot for your motor.
