The T/A's new heart
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
The T/A's new heart
heres a pic of my new motor im gonna be putting in in the next few weeks.
Specs- Stock bore 350 out of a 1998 silverado.
-hyper flat tops out of an lt1
- stock vortec heads with upgraded springs and 1.6 stamped roller tip rockers
- Comp XE274 hydraulic flat tappet cam
For the top end i got a RPM airgap and a quickfuel q750dp mech. secondaries and a summit ignition kit with blueprintd hei and cdi box with limiter. and those are Hedman longtubes 68460's
behind it will be a b&m th350 with 3000 holeshot converter.
anybody got any guesses for what she'll do in the 1/4?
Car: 1983 trans am
Re: The T/A's new heart
yes but it currently has flat tappet lifters and cam cause i bought the long block assembled and thats how it was. later i plan on swapping to some aluminum heads and a rollercam and lifter set that'll really wake her up but this is my first motor and it wanna start out easy.
Carb is a little on the big side. Most vortec setups with 650DP's run high to mid 12's with such parts mentioned depending on tune and driver. Sounds like a good combo though if certain areas are addressed.
Car: 1985 IROC-Z Silver
Engine: Vortec 5.7L
Transmission: WC-T5
Axle/Gears: 3.23 disc brake 10 bolt
with some ET streets that thing oughta go LOW 12's.
- Carb is FINE!
Get an X-pipe set up on there and it will make some good power. Fab up some sort of cold air too.
- Carb is FINE!
if i were you, i'd yank that cam/lifters back out and sell them before you run the motor. will get more money.
get a stock set of roller lifters and a roller cam your happy with.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
have the guides on the heads been milled for clearance to run bigger lift?
the combo that you have right now has been known to go into the upper 11's once setup correctly.
Car: 1983 trans am
the heads have been machined for bigger springs and i wanted to go with the bigger carb so i dont have to upgrade carbs later. i do have a true dual setup i bought off of smokin87ta im goin to run and an x pipe i gotta fab into it. thanks for all the replies guys my goals with the motor was to do high 12's on street rubber and mid- low 12's on drag radials and beat my friends 94 cobra haha
I have a question. Are those the vortec heads in the picture? I thought that vortecs had three triangles in the front of the head. If those are the vortecs could you give me the cast number please.
About the motor, i have a similar setup and im in the tunning process with it now. Trying to tune a 750 VS carb on it and i can tell you the motor would do better with your choice of carb (Mech. sec.). I did some shake downs passes with a 1800-2000 stall and shifted at a low 4500 RPM with a VooDoo 268 cam and pulled a 14.0 @ 102 w/ a horrible 2.2 60'. So with a similar set up good traction and shifting at correct RPM i would expect some 12's. Oh yea on my pass i didnt even get to tune it, so put the carb on the motor set base timing and drove.
Car: 1983 trans am
yes those are vortecs in the pic. i dont know the #'s off the top of my head and the motor isnt at my house. i think it was something like 989 or 889 or close.
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
I would definitely put in a hydraulic roller, you will be so much happier, and it's a lot more piece of mind. with a bone stock vortec motor in my car i run about 8.3 at 83 mph i believe. the GMPP hot cam is an excellent choice if its a street car still, or the XR288 is an awesome grind if you want a more serious idle. Just be careful of retainer to seal clearance
Car: 1983 trans am
im gonna run the motor the way it is for now and if im not happy with it i can swap the cam in the car.
2012sergen11
10-13-2015 07:38 PM
