What would this stang run?
Car: ws6
Engine: ls1
Transmission: m6
87-91 Im not sure of the year. 5.0 body style. 5-speed 302 bored to 306. Heads, camed, 3.55 gears, exhaust and headers? Sorry I dont know the full specs and neither does my buddy who bought the car.
Car: ws6
Engine: ls1
Transmission: m6
Re: What would this stang run?
Really. I thought they ran 14.5's with a 5 speed. bolt ons and internals I would think a mid 12??? no... wheres 25th
Car: 1991 Z28 - 2000 Z28
Engine: L98 - LS4
Transmission: 700R4 - 4L60E
Axle/Gears: 3.23's - 3.73's
I'll go out on a limb and say anywhere between 12.9-13.4 @ 101 - 105 MPH. How light is the car? Does it hook? Etc...
Just an example, a good friend of mine has a 95' GT. It's a stripper car w/ crank windows, etc. It weighs in at 3240 w/o driver. The car has: CAI, 90mm L-MAF, 30# injectors, 65mm TB, Edelbrock intake and heads, Crane 2031 cam, Roller rockers,BBK LTs, X-pipe, 2.5" Max flows w/ dumps, CF DS, 3.73's, Tremec TKO, adj. drag shocks, SSM upper & lower LCA's, Weld drag lites w/ skinnies and MT 275/50-15 DR's.
It dyno'd 290 RHP & 324 RWTQ. Best time to date was 12.427 @ 109.10 on a 1.662 60'. It's a light car, decent driver, lots of suspension mods to compliment the engine mods.
I would have to agree with diggler!
Really depends - I have seen many run not much better than stock, however I have seen some in the 10s N/A. Like my friends, stock internal 302 - pistons not even cut yet,ported trick flows, holley system max also ported running 10.7@126, however car weighs 2800 with driver and alot of RandD work on car. Still very impressive no doubt. But really depends on combo, and much driver.
Ask at stang boards were they would no with what combo it would run.
www.steelcitystangs.com is pretty cool.
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
theres many bolt on 5.0's around here running in the 12's with stock heads and cam so if your buddies has cam and heads depeding on specs i would say expect 12.60 or faster.
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
how can anyone guess without more info on the car? could be 12.5 to 17 who knows without more specs. btw things have to work togather to make power.
Fast355
12-02-2016 06:33 PM
eightsixseven
08-14-2015 03:09 PM
