Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Dzus fastened hood questions
Old 04-06-2008 | 09:15 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Guys I have ordered my lift off hood and am needing some ideas/pictures from guys who have a dzus fastened hood. How did you mount your brackets for the front of the hood? I have a few ideas but, would like some input as to where you have yours mounted. Thanks!
Old 04-06-2008 | 09:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Dzus fastened hood questions
The only thing keeping me from getting a complete lift off hood is that it's just about a 2 person job to get it on and off because the hood is so big.
Normally, there are 4 Dzus fasteners along the sides and 2 or 3 across the front. Install brackets any way possible to attach the retaining springs.`
I'll live with my 2 hood pins and the factory hood hinges and shocks. With the fuel cell under the hood, I need to open it after every run.
Old 04-07-2008 | 09:43 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
Always have at least one other person with me since my wreck....had the factory hinges and pins with the last hood (steel, with cowl scoop) wanted to go light so I went with the lift off. Already have my four down each side just trying to find a good place for the 2 in the front.
Old 04-07-2008 | 06:14 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
Anyone else??? I know that I have seen alot of cars with dzus fastened hoods on this site.....Matt how did you fasten yours?
Old 04-07-2008 | 09:08 PM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
build a bracket that goes between the headlight support and the radiator support that has the tabs/retainer on it. Like this:
Old 04-07-2008 | 09:30 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
Thanks for the pic....
Frozer!!!
01-19-2024 05:55 PM
Black89TA
Exterior Parts for Sale
07-23-2016 11:42 AM
ASE doc
Alternative Port EFI Intakes
08-25-2015 10:14 AM
redmaroz
08-17-2015 12:40 AM
