Going to the track, what do you think..
Car: 89 Iroc-z
Engine: 396 Stroker 625hp
Transmission: 700r4 3000 stall
Im going to the track and wondering what my combo will run. Heres what Ive got.
-396 Small Block
-11:1 Comp.
-Cam specs .539 / .548 Duration: 296 / 300 Lobe Sep: 112
-Comp 1.5 RR's and girdles
-Edelbrock E-tec 200 heads, ported and polished 64cc
-Edelbrock RPM Air Gap
-AED 750 HPHO
-Edelbrock Performer RPM Nitrous with 175 shot
-Dougs 1 3/4" Long Tubes
-3" true duals with dyno max bullets dumped
-MSD Digital 6 Plus
-MSD Pro-billet distributor
-Moser 9" with 4.11's
-All Sphon tubular adjustable suspension
-700r4 built with 3000 stall (I know, I know )
-Weld draglites 15x8 in the rear with 275/60/15 M&H slicks, 15x3 with MT front runners on the front
-8pt cage
-car weighs 2500lbs with me in it
-396 Small Block
-11:1 Comp.
-AED 750 HPHO
-MSD Digital 6 Plus
-8pt cage
1 Post
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
Re: Going to the track, what do you think..
2500lbs with you in it????? You sure about that. maybe 3500 lbs
Car: 89 Iroc-z
No, the car says it weighed 3273lbs from the factory, and I have reduced that by about 800lbs give or take. Might be a little more than 2500lbs but not much.
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
I don't think anyone here has a car that weighs less than 2500 pounds. At roughly 2300 pounds for just the car is just not possible. Take it to a certified scale. Thats the only way to know for sure!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
There is no way your car is 2500 pounds race weight unless you have a tube chassis car and a lot of fiberglass parts. Go find a scale somewhere and get the weight with you in it. You'll be very lucky if you're even close to 3000 even with a full cage. My car is completely gutted, Lexan windows, has a full cage, BBC and is back halved. My race weight is just under 3200 pounds. I actually took weight off doing the back half.
Without knowing an exact race weight (don't guess) I'll take a wild guess and say high 11's to low 12's. With the 700R4, 28" tall tires and 4.10 gears, I may change that to mid to high 12's. It depends if it will hook up at all. Your engine isn't much more than my old 383 which ran very high 11's at altitude.
Car: 85 Camaro
Engine: 437" small block
Transmission: glide
Axle/Gears: 3.70
I have to agree with the above people. No way it's 2500 pounds. You may have taken some weight out but you also added a cage,nitrous system and a 9" rear. My guess is your in the 3200 pound area. At that weight I'm thinking high 11's low 12's N/A if it hooks and the air is good. Low 11's ot high 10's on the bottle if your a decent nitrous tuner and your chassis works. I'm figuring the elevation in florida isn't real high. But only one way to tell. Take it to the track and run it! Let us know how it goes.
Car: 89 Iroc-z
Alright guys, I'll go weigh it on a certified scale and let you know. Also, I have a chance to get a TH400 with a 3500 stall and brake, would that help me lower my ET's?
Car: 87 IROC L98
It'll add some weight and eat a bunch more HP but will be more reliable and have a better gear ratio. You'll also need to get a proper tranny slip yoke and different length driveshaft.
A converter that stalls closer to 4000 would be better for your camshaft choice.
