New Best 8.61 @ 159
Car: 85 Camaro
Engine: 437" small block
Transmission: glide
Axle/Gears: 3.70
New Best 8.61 @ 159
Went to cecil county to make a few shakedown passes on saturday. Here's the numbers from my best pass. This was only the 5th pass on the new setup and only the 2nd pass with the nitrous this year. Pass was made on drag radials through the mufflers at 3350 pounds. Had the car setup to leave pretty soft since I wasn't sure what the track would hold. Looking to improve these numbers a bit next weekend.
60' 1.276
330' 3.620
660' 5.549 @ 127.55
1000' 7.209
1320' 8.619 @ 159.70
60' 1.276
330' 3.620
660' 5.549 @ 127.55
1000' 7.209
Car: Pair of 92 Z28s
Re: New Best 8.61 @ 159
Amazing...i've seen your car in person a few times at O.C. 8.61 car that can drive reasonably well on the street .
Btw isn't that your car on Spohns front webpage?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
thats just sick man
i am only hoping to touch 10's on the spray which should happen, but your car is sick. maybe i'll make something like that someday
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Wow, that's turnin and burnin baby!!!!! Good luck with this next weekends tuning and keep the shiney side up
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
Congrats man, awesome as usual. What did the car go on motor? wheels stands?
Car: 85 Camaro
Transmission: glide
Axle/Gears: 3.70
The only motor passes I made were 1/8 mile because the shutdown area was wet in the morning. It was real slow with the new converter. It leaves like a turd on motor. I had the wheelie bars on since I didn't know what it was gonna do. It dosen't leave nearly as violent as last year. I should be able to take them back off with a little tuneing.
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Well thats good no more breakage or flat headers. Did you put the new ones yet or still have the hookers on it?
60' 1.276
330' 3.620
660' 5.549 @ 127.55
1000' 7.209
60' 1.276
330' 3.620
660' 5.549 @ 127.55
1000' 7.209
i guess those headers made a differece after all
Car: 85 Camaro
Transmission: glide
Axle/Gears: 3.70
Yeah they helped. The new converter and cam made a differance as well I'm sure.
Last edited by radialtireking; 03-17-2008 at 03:54 PM. Reason: Automerged Doublepost
did you switch to a ccx stator in the convertor?
Car: 85 Camaro
Transmission: glide
Axle/Gears: 3.70
Car: 1984 Firebird T/A
Engine: 406sbc
Transmission: TH400
Axle/Gears: Moser 9"
Damn How much nitrous do you spray? I was considering doing a 200+ shot once I get my bottom end built up on my other motor.
Car: 85 Camaro
Transmission: glide
Axle/Gears: 3.70
That pass was a 300 shot according to the jets. I had it setup really safe as far as timing and fuel pressure since it was the first pass,so it wasn't gaining its full potential. This weekend I plan to start dialing it in closer. Low 8.50's @ 160+ shouldn't be a problem with these jets.
Car: 85 Camaro
Transmission: glide
Axle/Gears: 3.70
With the cam and converter setup for the nitrous and the taller tires it slowed down N/A from the old combo. I only made a few 1/8 mile passes with this motor since the track was wet in the shutdown area in the morning and it went 6.52 @ 110. I figure it will go about 10.20 @ 138-140 on a full motor pass. It dosen't really get going till about 200 feet out on a motor pass.
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
I just picked up a job with Trans Specialties. First thing i saw when i went in was your picture on the wall. What has been your experience with there products? They seem to have thier stuff together wen it comes to racing converters.
TransAm12sec
Aftermarket Product Review
10-06-2003 12:40 PM
