4.10 to 3.73 dif?
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
4.10 to 3.73 dif?
i have 4.10 in the car now. i was wanting to know how much going to 3.73. how much will this hurt my 1/4 mile time?
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Re: 4.10 to 3.73 dif?
ill throw a ballpark figure out there of .1- .2
Car: 1972 SS Nova, 1991 Camaro drag only
Engine: Stock 350, 355 w/12.5's
Transmission: 350 auto's
Axle/Gears: 3.55, 3.73
Car: 89 Formula Firebird
Engine: 357
Transmission: turbo 350, EDGE 3500 stall
Axle/Gears: GMPP Dana 44, 3.73 gears
I run pretty close to the same set up you have in my Formula. I have a little bit bigger cam, lunati 00013lk .500/.515 plus 1.6 rks on top of that. I also run 28 in tall et streets. The best on mtr has been 12.68 at 107 and on a safe tune 100 shot 11.58 at 117.5. It only 60's in the 1.8's but pulls like a freight train in the last half of the track.
saturday made a pass with a 1.77 60ft and 12.940 1/4. but it would of been better if i had not shifted it at 4000 in to 2nd gear. but about 100 lbs heavier than last yr.
I went 7.81 with my son driving this past weekend. He is 14 and only weighs in at a mere 125 pounds. He drives like a veteran though. He won the 9.0 championship last year. We run down in Arkansas at George Ray's. So all we get is the time no 60' or anything. We hope to go to a better track soon as the water dries up some.
[ON] 9 Bolt Axles Partout
6speedIROC
16
03-15-2023 08:33 PM
