chain limiters
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: chain limiters
Limiters on the front suspension restricts weight transfer.
Limiters on the engine keeps the engine from torquing over in factory style rubber engine mounts. This can have a lot of problems with transmission mounts, mechanical clutch linkage, mechanical fuel linkage, hood clearance from an air filter etc.
By chaining the engine down, you also reduce or eliminate wasted movement. Instead of the engine torque over, it will try to pull the frame upward.
Polyurethane engine mounts do a good job of controlling this movement and solid mounts eliminate it.
Car: 1987 Camaro
Engine: 406
Axle/Gears: Moser 31 spline / 4.86
Re: chain limiters
I run chains on my front end to make the car react quicker. The car shoots out instead of up then out.
Re: chain limiters
since you state weight transfer, I am guessing you mean front suspension extension limiters, and this is when they become helpful.
or, here where they need to be shortened more
a lower horsepower car will need the extension of the front to keep the rear tires loaded, I can not tell you what that number is for your car, since every setup is different.
so I guess the answer is when you have flattened headers, or scraped rear bumper cover...
skinny z
10-05-2015 06:23 PM
