Who's car is this?
Car: 1987 Pontiac GTA Trans Am
Engine: Basic Stroked SBC..383
Transmission: PerformaBuilt 700R4 3000 Stall
Axle/Gears: Moser 9in. 3:70s
Re: Who's car is this?
Idk if that was 7s in the 1/4 or 1/8s butt thats at 190 thats freakn fast..on MT Drag Radials..not slicks...bad bad car
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Photoshopped!
Just kidding, 190 mph is holding on for dear life though in a d/r car.
![driving](https://www.thirdgen.org/forums/images/smilies/driving.gif)
Car: '91 Camaro RS
Will Stevenson's. Conventional headed 509ci BB Chevy with a blow-thru Dominator from CSU and an F3R Procharger.
http://www.danneumannracecars.com/Pictures.html
![](http://www.danneumannracecars.com/images/DSC05396_Medium.jpg)
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
holy moly that this is a BEAST!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Thanks for the engine pic. I was going to say if you pause the video just as it starts, you can see the tubes going to an air charge cooler through the back window so it had to be a turbo car.
Car: 87 IROC L98
ok, same thing. Uses boost as opposed to a NOS car but that doesn't explain the soft launch.
boost controllers hooked to a bov maybe? i honestly don't know...unless he simply rolled into the throttle instead of blasting out. cause a crank driven supercharger doesn't need to "spool up" like a big single turbo does.
he could have pulled a ton of timing and added it back in as the car went down the track, much like a boost controller or progressive nitrous controller. those guys are also running high $$$ variable stall converters and crazy stuff like that (not saying this guy is, but alot of them do)
Car: 85z28
Engine: sbc
Transmission: th400
Axle/Gears: 3.80 gear 35 spline axles
when they launch a car like that they pull out alot of timing and ramp it back in as it goes down the track.
Linson
08-21-2015 02:12 PM
car, drag, f2, f3r, jacksonvillenc, ls1, pics, price, procharger, radial, radialsslicks, sale, stevenson, supercharging, techniques
