what do you think it could run?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Im not really setup to go straight, more of a handling orientation, but i'll get the opinions anyway
86 Trans Am
408 stroker
10.44 comp
288/294 dur .520/.540 lift with 1.6 rockers 110 lobe seperation
501 flywheel horsepower
520 lb/ft flywheel torque
tko600 5 speed
3:73's in a 10 bolt
UMI torque arm, control arms, panhard, alston connectors, coil-overs on all 4 corners, koni's up front QA1 promastars out back
i dont know the curb weight, but its got a glass hood, aluminum heads and accessories, no emissions stuff, rear seat delete, no spare/jack, and rolling on some classy 18" heavy as all hell aluminum wheels with street tires
ballpark ideas, provided i can get traction?
thanks
86 Trans Am
408 stroker
10.44 comp
tko600 5 speed
3:73's in a 10 bolt
thanks
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
Re: what do you think it could run?
low to mid 12s.....the big wheels are holding you back....try some drag slicks on 15" wheels
Im not expecting the 10 bolt to be around long, just waiting to get a few other projects finished and i'll be picking up a moser 9", would a 15" wheel fit over ls1 rear discs? If so i may pick up a spare set of rims and drag radials for when i finally hit the track.
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
Hey is that the T@L 408. Did they actually dyno Your motor to come up with that 501 horse figure? I'm really close to getting one myself. If so.... I can forsee maybe high 11's or low 12's at well over 110 mph with some 15 or 16" rims and an ok tire. A good tune will help obtain those numbers. I read a few posts above and I doubt You'll run anthing worse than a mid 12 with 500 horses.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
you'll have to grind the calipers, but you can make a 15" fit over the ls1 rears.
Car: 89 FORMULA 350
Engine: 5.7 L98
yes its from T@L, its the A-2. Its broken in, dynoed, tuned and everything before its shipped, i honestly dont know how into the tune they get, whether them have a baseline or if the actually play with it to get it perfect. They are a good company, i would recommend them, lloyd is a very knowledgeable person and the whole deal was a pleasure, though plan accordingly, from other people ive talked to, the average time from order to delivery is about 3 months for a complete engine.
i got a moroso 6qt pan, made for the bird. Its is not y-pipe friendly though
Car: 89 FORMULA 350
Engine: 5.7 L98
dANG!! What did You do then? Did You smash the pan in a little or did You have a custom y pipe fabbed up?
anyone know how to make a 305 chevy 1985 faster than fast?
titooriz2215@yahoo.com
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
500 at the flywheel should yield you over 400 at the wheels.. i dont even lay down 400 at the wheels.. bottom 11's with a 1.5xx-1.6xx 60ft time.. might even hit 10's if you give it more gear.. 3.73 is conservative for drag as you can tell, i'm running 4.30 and i still need more..
also, can you bang gears well?? it can make up to .3 difference.. i trade off with my dad and on perfect runs, i'm .3 faster..
I can bang gears real quick, even using the clutch to some extent.
the 3:73 work for me as a street car, im not setup for drag racing. I wish i had some numbers to give you guys but i have this nasty habit of tearing the car apart all the time instead of driving it.... its almost back together , again...
Fast355
12-02-2016 06:33 PM
eightsixseven
08-14-2015 03:09 PM
