1/4 mile times?????
Car: 89 formula 350
Engine: 5.7L (L98)
Transmission: 700R4-(shift kit,corvette servo)
Axle/Gears: borge warner-3.27
1/4 mile times?????
Has anybody ran at the track with similar mods like mine and what times did you pull? I haven't had time to do the track this year and the only problem with my G-Tech is that I spin tires through 1st and 2nd gears so it is right now in-accurate. I need to get some slicks for the rear obviously before hitting the track. Much better power now with the cold air.
Car: 1991 Camaro B4C
Engine: L98 350 cid (5.7L) TPI v8
Transmission: 700 R4 auto trans
Axle/Gears: 10 bolt w/girdle & 3.42 MotiveGears
Re: 1/4 mile times?????
My 1991 Camaro RS - B4C
Weighs 3660 with me in it.
Has 145,000+ miles
Has made countless 1/4 mile passes.
It now typically runs between 13.7 to 13.9 @ 97.9 mph
on the 1/4 at Kansas City International Raceway (KCIR)
temperatures were around 85*-90* with 25-40% humidity.
The elevation there is around 800 feet,
In really good air (cold, low humidity)
It has run a best of 13.52 November 12, 2006.
I slowed down a little last year with my best
time only being 13.608 @ 99.27 mph
in 51.3* temps with 69% humidity.
For a complete list of mods you can check out my
Drag Times page for a quick read:
http://www.dragtimes.com/Chevrolet-C...slip-5874.html
Or if your really bored and want to spend some
time reading a lot of bs you can check out my
cardomain pages (I'm kind of long winded don't ya know)
http://www.cardomain.com/ride/2175519
Has 145,000+ miles
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
I ran a 14.10 at almost 99 mph with less substansial mods than You. My mods are listed in my profile.
SWEET !!!!
Car: 89 formula 350
Engine: 5.7L (L98)
My goal for now is to try and hit high 13s in the quarter. Maybe 13.8 or 13.7 possibly. I also am thinking of doing nitrous for this spring coming up. That and slicks should probably put me in the low 13s. What do you guys think?
Car: 1986 caged out firebird
Engine: 454 = wheelies
Transmission: th400 stall and trans brake
Axle/Gears: 4:11 ford 9" with ladder bars
i think u should just build ur engine instead of spraying it you should get the hp first then if u want a little more spray it but thats just me
Car: 89 formula 350
Engine: 5.7L (L98)
hey trans am 360. Nice to know somwone local around here. we'll have to get together this year for some fun on the streats. It's all good. I am always working to get the hp numbers up.
for sure man we will meet up sometime next spring and do a little cruzzin
evilstuie
01-09-2020 08:29 PM
