got my 28x12.50s to tuck
Re: got my 28x12.50s to tuck
that's with 10 pounds of air in the drag bag on the pass side and 5 pounds on the drivers side....it raises the rear up a bit maybe 1.5". Haven't figured out how to have air in the bags and not have it raise the car just yet. With no pressure in the bags the rear springs are too soft even though they're WS6 springs.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I was thinking the same thing after looking at the pictures. Even with the tall tires, the back end is sitting too high. I don't think my car sat that high when I had 29.5 x 10.5 slicks on it.
Ditch the air bags and install a good aftermarket anti-roll bar. I already see a rear sway bar which will help but it's not quite the same.
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
sick.. any pics of the work??
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
S E X, pure adult, x-rated, make sure the kids are asleep, bought a bootleg dvd at the flea market S E X X X. man awesome car i love it, what size wheels are those and what was involved to get all that meatiness to fit? oh yea did i mention i love it? lol
it took 6 more hours of cutting that the 15x10 with 5.5bs and 28x10.50s instead of the 6.5bs and 12.50s now. Don't have a chance to get pics of what all is removed, but the front corner is gone, as is that outer rail, along with the entire bumpstop area and all the ribs behind that as well. Basically kept putting up a 18" pry bar until the entire wheelwell was flat with the spring pocket.
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
so if i understand correctly you basically made a mini tub with just bending the metal that was already their?
removed a LOT of metal and welded in my own sheet metal out of 16 or 18 guage steel....I don't remember which one I bought. But still have some finish work to do, but mini tubs are coming this winter unless I don't have time, I prefer it to look more professional, even though you'd never see the cuts, one giant tub would look cleaner.
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
Very nice job on getting those tires to tuck like that. Like others have mentioned could you post some pics of the work you did?
im just scratching my head on how you got the 6.5" wheels to work.... lol that had to be a crapload of work. my 5.5" wheels are TIGHT even after doing tons of work. my 28x10.5 hoosiers are basically the same size as your 28x12.50 dot tires.
anyways, i would ditch the bags and run a bmr drag swaybar. it bolts up like a stock one, only its waay bigger. works great at the track, and works great on the street. (unlike the wolfe)
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Car looks great let see a picture after you lowered the car. And on the moser and I am assuming all after market axeles the axel tubes are larger in dia and the spring perchs are moved up a little I had to cut my springs after axel swap also.
I'll get a pic sometime tomorrow while getting the boat ready for lake michigan salmon thursday Yes the moser housing raised the rear a bit, 1/2 coil is taken off right now, might cut another 1/4 coil or 1/2 coil depending how it settles down. I also removed the rubber isolator, which was only worth 1/4" or so of drop, but at least if I cut too much out of the spring by 1/4 coil I could add the isolators back in.
Car: 1984 Trans Am
spohn makes a 1-5/16" drag bar.. $375.. i was thinking about getting one.. my drag bag consists of 4 coil spring spacers.. ghetto, i know.. but it works..
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Wow, that right there is a show car. Hope it goes as well as it looks eh?
Are those tires DOT legal? I always assumed a tire measured in imperial is a non-street legal slick?
Car: 1982 Trans-Am
Ah, with your little 350 eh?
Ok, so you can "legally" drive them on the street. Does it drive "really weird" compared to a "normal" tire? Say compared to a BFG 275/60/R15, a normal treaded large car tire?
That's an unbelievably clean underbody. I'd also like to see how the ride height looks now, as well as what the fenderwells look like now.
yea just a stock bottom end 350 nothing fancy, just junk no one else wanted and a parts combo that works together nicely
If you've never driven a car with slicks before at 50mph or so the back end of the car sways back and forth because of the sidewalls being so soft. I run 18 pounds on the street and it just see saws back and forth, you get used to it. Ride height pics will have to wait until tomorrow evening at best, boat is on the driveway along with my suburban and another suburban, so the camaro is stuck in the garage.
Car looks great! I'm running 15x10 with 5.5" of bs on a 28x 10.5 MT ET Drag and I thought it was a snug fit (mild fender work) and I totally agree with you on the drive quality with a car with slicks ... I suggest anyone who puts them on to first drive around the block and some side street before you plan to rip down any main drags or strip (I run 20 in them off track .. they dont sway to bad with them like that but I will never run drag radials ever again ... made the switch and love the results) anywho .. car looks great man!
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
metal work, metal work, metal work.
metal work pics will be out another 2 weeks when i finalize the sheet metal. I'll shoot for a pic of the car out of the garage later tonight when I drive it to a local car cruise, there is still a 2"x6" strip of metal missing on both sides that duct tape is taking care of for now. In the lower front where I had to reshape the metal into more of a box shape.
mini photo shoot here.....
with the way the suspension is setup the pass. side is 1" taller than the drivers side, so that's why the pass side still looks a little high compared to the drivers side, also I'm parked on a lawn
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
Looks good Nice ride
Arent M/T's 28x12.5 a 10" tire? That was the main reason I originally went to Hoosier, scince their 28x11.5 is the same tread width as M/T 28x12.5 and some races I've run call for a max 11.5" sidewall designation on DOT tires.
28x11.5x16 Hoosier QTP DOT on stock wheels
28x12.50 ET street has 10" of tread width, but the section width is 12.7" whereas a 10.5W ET drag has a section width of 13.1" so this is why I chose this tire initially as I want to run a W tire next spring, so I wanted to see if this slightly narrower tire would fit without a full on minitub first. Also a 28x10.5 ET drag has a section width of 11.8" so the et street is almost 1" wider in section width.
first the car looks much better now. and i have m/t 28 10.5 15w's under the back of an 87, uh its around here somewhere, on the bumper. it really didnt take much work for the tire, the brakes however were another story, it had wilwood 11.25 inch vented rotors and a 4 piston caliper now it has 10.75 inch rotors with 3 inch offset hats to clear the old forged centerlines that are on the car
Car: 91 maro
Axle/Gears: 373 locker
i have a set of 17/11 with a 12 inch tire on the back of mine she hooked so good it busted the crush sleeve in the rear and blew the housing new rear new gear.yea at the track weak *** 7.5
Car: 2013 C63C
Engine: M156 (P31)
B - Tread Width
D - Section Width
Like the 28x10x16 Hoosier slicks I used to run vs the 28x11.5x16 Hoosier QTP DOTs I run now, different numbers but the same size tires when measured.
Either way nice job, how did the car 60ft on the old 28x10.5 slicks?
Car: 91 maro
i never really use slicks i just get a sticky tire that ussauly dont last long like kuhmo'bf gdr;stuff like that my kuhmos would lay rouhgly 12 inch burn marks ile never have another set like that they quit selling that brand why? they hooked so nice
That second from last picture is BAD ***!!
#42
1 Post
Car: 82 Camaro
Engine: 327/30 over 1965 block
Transmission: 4 speed M22 trany
Axle/Gears: 373
Man can send pics and specs and the tires and rims size, Man I need to get wider tires under 82 camaro... jagcompany@aol.com an help on this...
#44
1 Post
Car: 82 Camaro
Axle/Gears: 373
It's not as clear there's about 7 other fdody guys looking at this. Can give a little more info step by step and pics if you can. Or if you have some enter site of more pics.... Like to make sure I have good understanding. And whats needed. I have a new tranny mount and torque , new forged steel 4340 panhard bar and control arms all forged steel. The other support bar will be remove and run 3 dual exhaust over the rear and out the back. If you can rim size back spacing what was completely need to do this... Any more info or pics would help a lot if you can, to jagcompany@aol.com
I was told 28" x 11:50 tires with 15 x 10 rim with 5.5 back space would fit with no work - just bolt on and go but not sure if this is true and if it would fit under the car and not stick out.
Before I start spending more money I just like to make sure I'm on the right track.
The car would run with 7.5 tires 12:30s in the 1/4 run but I guy let me use his tires of his car there size was 12.5 x 15 but the stuck out about 1.5 out of the sides. But man they got man down track low 11s the springs I have are new the rear body go's down just about a 1/2 so they did not rub at all. After few runs with his tires the front wheel right side would come of the ground about 6" to 10" I will be doing some work next year on the frame...
Any help on this if you can. Thanks for posting this to...
#45
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
#46
1 Post
Car: 82 Camaro
Axle/Gears: 373
No it's cool, I thank I in there now plus found some other pics.. Thanks
Do you no if the fitment for 28 x 11.50 tires with 15 x 10 rims with a back spacing 5.5 will fit with out any work and will fit under the fender wall
The back spacing was not spell out, We did not no what that mean,
#47
that came oout really nice, but i dont understand why u had to do so much work
heres a picture of 28x10.5 slicks on my car, lil bit of hammering on the bumpstops and front of the inner wheel well.other then that i have 1/4 inch thick wheel spacers
should be the same width as ur dot tires
#48
#49
again i posted the section width differences, these tires are almost 1" wider in section width which caused all the issues. Along with no spacer means 3/4" further inside the wheel wells than what you're running along with needing 1/2" or more gap between the tire and body of the car due to the spool pulling the slicks over in a turn.
