Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
NHRA/IHRA rules about battery relocations
Old 09-09-2007 | 09:33 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I was told by a friend that if the battery is not in the stock location you need a cutoff switch that is VISIBLE FROM OUTSIDE THE CAR... is that true? If so, looks like I'm not racing anymore!
Old 09-09-2007 | 11:20 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: NHRA/IHRA rules about battery relocations
IHRA and NHRA rules for battery relocation are the same
All batteries not in the stock location must have a master switch mounted at the rear. Off must be clearly marked. If mounted in a push/pull configuration, push is to be off. Switch cannot be made of plastic or keyed. Switch must be installed on the positive side of the battery and must shut off the engine when turned off.
Some people with street driven cars mount the switch inside the car with a removable rod that extends out the rear. When driven on the street, the rod is removed.
If you don't like the rules, don't relocate your battery.
Old 09-09-2007 | 11:33 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
I mounted mine under the frame rail, and ran the wires through the access plug in the spare tire tub. The switch/connections were all heavily coated with moisture-proof grease afterwards to keep things corrosion-free. The access plug was sealed back up with RTV once install was complete.
http://www.eecis.udel.edu/~davis/z28...ch/switch1.jpg
(My muffler is a single exit out the drivers side, so this area was clear.. YMMV)
The rod hangs down below the bumper, and is removed when not at the track.
http://www.eecis.udel.edu/~davis/z28...tchhandle5.jpg
I just put a piece of Tape on the Bumper with the "Push OFF" wording..
It passes Tech, and I didn't have to drill holes through the rear and lights..
Old 09-09-2007 | 01:34 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Not bad! That looks really good. I thought the switch itself had to be visible or something.
Old 09-10-2007 | 06:19 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Best one I've ever seen is a vanity license plate "OFF ON", with a switch in the middle of the plate. . .
Old 09-12-2007 | 10:44 PM
NICK84Z's Avatar
Car: 84z28
Engine: none
Transmission: TH400
Axle/Gears: moser9" 411gears 31spline
I've seen a picture of one mounted behind the black plastic cover (where the plate lights are) of a camaro tailight so it was covered when they were street driving and they just took the little black cover off at the track
Falcon50
08-22-2020 04:26 PM
RS Reaper
10-17-2018 08:52 PM
loud91rs
10-05-2015 11:05 PM
meeklay812
10-01-2015 04:46 PM
drumstixer
09-29-2015 04:02 PM
