iroc wheels vs center lines
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
iroc wheels vs center lines drag wheels 14x6 which one would be best to use in the 1/4 in front ?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Re: iroc wheels vs center lines
whatever fits over the stock brakes and is the lightest would be my guess. i would bet the centerline is lighter... irocz wheels in 16x8 are HEAVY and slow you down. smaller tires for less rolling resistance would be better as well
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
unfortunately, niether one has a really good tire offered in those sizes. 16's have more than the 14's, and the 16x8 will spread the tire out more than the 14's...i would put the 14x6's up front for the reduced rotating mass, but keep the 16's out back for tire selection, then find a 15x8.5 or 15x10 centerline to match for the back later on down the road.
colton_carlson
03-08-2019 01:21 PM
kah992
08-19-2015 03:55 PM
mustangman65_79
08-11-2015 04:17 PM
