First time at the track.
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
Mostly stock with a dynomax catback and some sphon sub frames on there. Air foil.
First run: Very nervous launched at like 3k or something ridiculous and didnt get traction till 2nd
R/T .522
60' 2.56
1/8 10.32
MPH 71.91
1/4 15.78
MPH 90.61
Second run: Still uneasy lauched a little better still no traction all the way through 1st.
R/T .654
60' 2.48
1/8 10.06
MPH 73.09
1/4 15.44
MPH 91.86
Third run: Tried something different here. Just kind of eased into the throttle. Bogged out a little bit. But good otherwise. Also took my air filters out.
R/T .806
60' 2.28
1/8 9.74
MPH 73.47
1/4 15.10
MPH 92.31
Well, i had a blast definatly going to be goin back to the track
Any tips or helpfull info welcome.
jake
R/T .522
60' 2.56
1/8 10.32
MPH 71.91
1/4 15.78
MPH 90.61
R/T .654
60' 2.48
1/8 10.06
MPH 73.09
1/4 15.44
MPH 91.86
R/T .806
60' 2.28
1/8 9.74
MPH 73.47
1/4 15.10
MPH 92.31
jake
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Re: First time at the track.
R/T .522
60' 2.56
1/8 10.32
MPH 71.91
1/4 15.78
MPH 90.61
R/T .654
60' 2.48
1/8 10.06
MPH 73.09
1/4 15.44
MPH 91.86
R/T .806
60' 2.28
1/8 9.74
MPH 73.47
1/4 15.10
MPH 92.31
jake
R/T .522
60' 2.56
1/8 10.32
MPH 71.91
1/4 15.78
MPH 90.61
R/T .654
60' 2.48
1/8 10.06
MPH 73.09
1/4 15.44
MPH 91.86
R/T .806
60' 2.28
1/8 9.74
MPH 73.47
1/4 15.10
MPH 92.31
jake
Thanks thats encourageing(sp). I will play with the psi next time and try to get a better launch. Hopefully i will get into the 14's.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Not bad at all. I can see you dropping into the 14's with no problem. Just get your 60' down a little.
CarGuyDennis
137
12-06-2016 11:02 PM
