Video: First pass with the Dart heads
Car: 1985 Z28
Engine: 355 topped with Dart heads
Axle/Gears: Stock axle with 3.73's
http://www.youtube.com/watch?v=5L8d9rp8hpc
Poor quality video, but you get the idea.
First pass with the Dart Iron Eagle heads and a new 750DP Holley. 12.52 @ 110 mph. I later bumped the timing up to 36 degrees of total advance and trapped 113 mph. I hope there is a little more left in it.
The other car was a '96 Z28, he ran mid 13's.
Car: 1985 Z28
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Video: First pass with the Dart heads
I don't think a looser converter will help on a 26" slick with 4.56 gears and that super deep 3.06 first gear in that trans. I feel that is too much torque multiplication right at the line and the converter is the only thing helping those tires to not blow off the line.
Car: 1985 Z28
I am actually running a 28" tire. I previously tried a 26", but it would practically destroy the tires.
Car: 1984 Z28
Either way that car will be a handful, that would be like running a 5.13 gear on a TH350
Car: 1985 Z28
Car: 1985 Z28
I have no idea how much HP it has. I suppose I could get an estimate based on the car's weight and trap speed, but I haven't weighed the car. The body is stock with the exception of a fiberglass hood and removed AC/heater box. Full interior.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
needs more cam, sounds like it needs more compression. you'll get far better results i think. those heads are huge.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
miss matched combo for sure, but it's moving the car along and band aiding a gear reduction problem for now.
you put a smaller gear and your stall speed will raise up a bit since you'll be riding the convertor harder without all the gear reduction.
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
I have a pair of brand new Trick Flow Twisted Wedge G2 aluninum heads for sale........I bought them for my 88 350 TPI FB but never installed. Also have Crane Cam 1.5 gold roller-rockers for sale.
ambainb
04-25-2016 09:21 PM
509 camaro fan
09-06-2015 10:43 AM
