how to calculate corrected HP?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
358 HP on an engine dyno, can we assume corrected to sea level?
NHRA has correction factors for ET & MPH, but not density altitude correction. http://www.nhra.com/tech_specs/altitude.html They call it "altitude", wish they'd call it elevation. Use the "Stock/Super Stock" chart. You'll have to use somebody's HP calculations from there.
Engine: LS1/LQ4
But did the dyno print-out give you a local as-tested/where tested HP number, or a corrected-to-sea-level number?
Wait, this was a chassis dyno? If you were given an engine HP #, it's highly suspect.
Re: how to calculate corrected HP?
There are formulas on the internet. I found a couple with a Google search. You will need to know the barometric pressure, temperature and humidity the time the dyno pull was made.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Depends what hp number you're starting with. A dyno already give you a corrected HP number. Calculating HP based on 1/4 mile MPH you use this formula. The first part is a simple common formula to calculate just how much HP it takes to move a weight to a specific MPH in 1320 feet. Don't use ET because it gets affected by to many other factors. If a car is set up properly and there's good traction, ET and MPH calculations should be very close.
Altitude Corrected HP = (race weight x (1/4 mile mph/234)^3) x Dyno Correction Formula
The dyno correction formula is the hard one. You need to know the Station press, Vapor Pressure, and air temperature.
Station pressure is the actual uncorrected air pressure taken from a barometer or altimeter. The barometric pressure given in weather forecasts is altitude corrected and won't work. Air temp from a thermometer in Celsius. Vapor Pressure is calculated. The formula for calculating due point from the local weather conditions is longer than what I want to type but can be calculated if you also know the humidity.
VP = (6.11 x 10^(7.5 x Due point/(237.7 + Due point))/10) x 0.2953
DCF = (1.18 x ((29.235/(SP-VP)) x (TempC + 273)/298)^0.5)-0.18)
Clear as mud? How about calculating Density Altitude?
http://www.hardtail.com/techtips/weather.html
These are some of the formulas I use to do my ET predictions. Once I know the corrected HP for the day, I can track how much faster or slower the car should run as the weather conditions change. Of course many things can affect the ET but the number I get is what the car "should" run and theoretically unless some weird thing happens, I should never run quicker than the predicted number.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
engine dyno's are notorious for bogus info based on shop it's in, some guys have their parameters for solid real world numbers, while others have their programmed to be very optimistic...just the way it is, and kind of funny when one guys dyno showed 950hp and the car actually runs 900hp numbers, so on and so forth.
Chasis dyno's and automatics...nother joke, take all those numbers with a grain of salt since the convertor messes readings up...my 388 in the sig below, supposedly when adding 20% back to areadings to compensate for drivetrain loss, that motor made 793ftlbs of tq LMFAO!!!!
Dyno's are nothing but a tuning aid, take all the supposeded hp/tq numbers with a grain of salt until you actually run the car down the track and get true life hp numbers.
sjorgens
10-01-2015 07:54 PM
