Another what will it run thread...
It's been done many times but I'm curious as to how my car will perform after certain mods. Right now the motor goes as follows:
357ci - bored .040 over, flat top pistons, 10:1 c/r, 1.5 rockers, 650cfm double pumper, torker 2 intake, Torker cam (232/234 @ .050 .488/.488 108 LSA), Ported & 2.02/1.60 '67 Nova heads (I think they are 468 heads), 700r4 built to handle lots of power, 2200 converter, 2.73 open rear (I know it sucks). What do you think that combo would run? It needs tuning right now as it's running so rich it burns my eyes when I lay into it. In the future the car will be getting a Super T10 trans and built rear with either 3.42's or 3.73's. What would it run with the trans and rear swap? I know it needs new heads so I'll prolly do a 274H cam along with the heads. I was thinking either Trickflow's or Edelbrock Vic Jr's. Let me know your thoughts guys...
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
Re: Another what will it run thread...
mid to low 14 need stall heads cam gears
That's pretty crappy
New parts:
Edelbrock Vic Jr 215cc
RPM Air Gap Intake
XE274H
Super T10 4 speed
3.42's or 3.73's
Any better choices for cam? It will be stroked to 385ci as well but for now the motor will pretty much stay put. The trans and rear however will be swapped as soon as I can get the time.
New parts:
RPM Air Gap Intake
XE274H
Super T10 4 speed
3.42's or 3.73's
with 3.73 maybe high 13
new stuff maybe low 12s to high 11
As that may be true (I checked the CHP flow bench data and they flow pretty well), I can still get them for a decent price so in my eyes they are the best bang for the buck so to speak. With the heads, cam and intake swapped along with the new trans and rear, I'm sure it will be a hella fun car to drive. I don't need a low 11 second monster but being in the 12's and maybe the 11's with spray is more then enough for me.
Being that I will be using the RPM heads, do you guys still recommend the XE274 cam? I know desktop dyno is a crock of ****, but it still makes me smile to see those high numbers
Fast355
12-02-2016 06:33 PM
eightsixseven
08-14-2015 03:09 PM
