First time at track....not to good
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
I`m a little disapointed with my times but they got better the more I practiced.My 60 ft are horrible and traction is a huge issue.I`ve got to get 3.73`s and some slicks.Everybody I raced beat me out of the hole but I would catch back up and even won a couple(barely). and would have won a couple more if it was a 1/4 mile instead of 1/8th cause I was gaining hard on everybody once I got traction.I spin all the way into third and bark the tires pretty good when it cathes.Best 60 ft 2.37.Best 1/8th 9.401 @ 79.19 mph.My speed seems pretty good.I just got to get some traction.What do yall think.What should I get first,Better gears or slicks/drag radials?Oh yeah,and what would that calculate to in the 1/4 mile?Thanks.
Car: '82 Z28
Re: First time at track....not to good
9.401 is roughly a 14.70 1/4 mile. Get those 60' times down and you'll drop your ET quite a bit. That being said, sticky tires before gears.
Car: 1985 IROC-Z Silver
Engine: Vortec 5.7L
Transmission: WC-T5
Axle/Gears: 3.23 disc brake 10 bolt
Yeah...MPH is good for 9.Oh's with a 2.0 60ft or so. Probably more like 8.90's.
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
I had a tbi 350 out of a 95 suburban with headers y-pipe and exhaust with a built 700r4 with 3.08 gears and i ran 9.70s on street tires with a v-6 rear end and i managed to get a 2.09 60ft but track prep was good and the 3.08s helped alot with traction,in your case if you plan on getting slicks or dr's and a stall it will help alot but you better be carefull with the stock rear..
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
Your mph is good for high 8s in the 1/8 mile. I run 8.6 with 82mph and 2.0 60ft. You need traction bad!!!
Car: 87 IROC Z
Engine: 5.7 L98 TPI
My trans and rear diff are both weak and could go at any time under hard driving conditions,so I am planning on upgradeing both as soon as money permits.I do need to keep practicing,This was my first time at a track so I should get a little better with time.I was with my son and really had no instructions it was just a watch and learn,trial and error type thing.My rear is already clunking and the pinnion seal is spraying gear oil on my undercarraige.Most of the races I felt I had the faster car just ran out of track.Think I`ll see 13`s with good tires/gears?Anybody got some 3.73`s for sale?
13s are very possible with any L98 car. I wouldn't go anyhigher then a 3.42 gear with the stock tpi setup.3.23s are great gears for the stock TPI.You can have all the gear in the world and if you don't get traction, its just a smoke show. Get some good slicks,a good stall 2500-3000, and fix the rear and you will run solid 8s in the 1/8 and 13s in the 1/4.Good luck!!
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Well I`m not planning on keeping the tpi stock for long.With an aftermarket base,runners and everything ported do you think 3.73 is still to much?
Car: 87 IROC Z
Engine: 5.7 L98 TPI
By the way.What do I need to get to in the 1/8th(mph/time) to be equal to 13`s in the 1/4 and or how do I calculate it
Seems the 3.73's stayed with the car all the way to 10.0 et, when my 87 was basically stock with a couple exhaust upgrades and tires and 3.73's in went 13.78, and sure ther was more left but did not want to wait to start modding.. also at that times was going to be happy with a low 13 second car..lol then low 12's then low 11's then low 10's and was destined for 9s this year till I totaled it..
Car: 87 IROC Z
Engine: 5.7 L98 TPI
87 T/A was that your car I saw all smashed in a week or two ago on here?There was a pretty long thread on it.If so I`m soooooo sorry man....Heartbreaker.
Ghettobird52
07-05-2024 11:18 PM
Linson
08-21-2015 02:12 PM
