new motor time...BIG traction problem!!!
Car: Iroc-z 86
Engine: 350 4bbl
Transmission: built up 700r4
Axle/Gears: ls1 4.10 posi
new motor time...BIG traction problem!!!(new time, now its better)
bad day for racing, cold about 45F(5cel), wet...
first run was my best run was 14.188 @105mph
2nd best 14.251@104.6mph
3rd 14.326@101.8mph
other where 14.5 an up at about 100-104mph
traction was bad but mph sould set me somewhere in the 13s???
didnt have 60' but they where almost 2.5-3sec
Seb
3rd 14.326@101.8mph
Seb
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Re: new motor time...BIG traction problem!!!
You should be able to go at least 1 second faster with your MPH. Some guys with well layed out setups have gone into the 12s at those speeds.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
i've been 12.8x's at as slow as 102mph, 105 is good for 12.6's.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
get some slicks initially and that should help a bunch. Do you have a stall converter or anything else? What's the combo and what's done to it?
Car: Iroc-z 86
Engine: 350 4bbl
my setup bfg 255/55R16 DR, 2200-2500 custom torque(stock size)no lock up, 4.10 gear, 700r4 full manual, with rod end LCA/Panhardbar...for the car
the new engine
performer rpm head, air gap intake, holley 650dp, xe274, 355cu.in, flowtech 1"1/2 header with 2"1/2 exhaust dynomax no cat(i know this is chocking my engine but its just for now) and a good tune, from an 20+ year of racing exp.
with my other engine i was able to pull 14.6@94mph....355cu.in, 882 head with 2 busted valve, stock iron intake, stock quad carb badly tuned and the same header/exhaust combo....zero traction issue the car as the same only the engine changed.
thanks for your answer
Seb
the new engine
Seb
Car: 89 formula, 89 Cadillac Brougham
Engine: 355,HSR,patriot alum. heads,TFS cam
Transmission: 700r4, 2500 B&M stall, shift kit
Axle/Gears: 3.73 ten bolt, powertrax locker
my car ran a best of 13.7@103/2.1 60's last year doggn' off the line on bald street tires
Car: Iroc-z 86
Engine: 350 4bbl
a little ?...wouldnt my mph be higher with incressed tration??My goal with this engine was low 13s hi 12s so im happy if i can get there with good traction.
thanks
Seb
edit....the d.a. of this day was about 5500ft
thanks
Seb
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
your mph will increase a bit but not extreme.. you should have no problems hitting low 13's.. high 12's will happen too.. i say you get down to 12.4 after all is well..
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
I was running 13.8's @ 95 mph, on a 1.89 60'. Get that car to hook, and you should see a minimum of 13.0. BTW what does the car weigh? Hard to make a lead sled run off of the line.
Car: Iroc-z 86
Engine: 350 4bbl
about +-3600pound with me and 1/2 tank, might go again this saturday since it will be in 80-85f range with sun and dry track...i might atleast touch 13s...but my posi is slowly going
Seb
Seb
Car: Iroc-z 86
Engine: 350 4bbl
new time today....and a new best of 13.007 at 106mph....smell like 12 if i can get better then 1.822 60'....i had my dr set at 16psi but the track was a little cold, outside temp was about 15degC and sunny, maybe on hoter day i could touch 1.7 60'... im crossing the line at about 6krpm in third and im shifting at about 6000-6500rpm, when im shifting earlier i get 13.2-13.1 e.t....my last 4 run where between 13.007-13.048, the posi was holding strong but i dont think it will last long.
Im now more happy with my new engine....did about 11 run and 2hr trip to the race track....its holding great im still in the break-in j/k
Seb
Seb
theshackle
03-05-2017 06:37 PM
CarGuyDennis
137
12-06-2016 11:02 PM
