How to determine right rear gear ratio??
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
Hey guys I am trying to figure out what gears to get when I buy my 9", is there a formula or a website I can go on to calculate what I need?? I am running a 28inch tire with a tremec tko600, and I dont want to spin my motor past 7k.. And I will be doing 1/4 mile not 1/8th. thanks
Re: How to determine right rear gear ratio??
Lots of calculators on here
http://www.wallaceracing.com/Calculators.htm
without knowing your trap speed we have no idea what to pick. I went 4.11 gears and 28" tire, knowing that it would be cheaper to swap to 27" slicks if needed that swapping gear sets out. With 7k for a redline and no power adder you could probably go 4.56 just guessing off the top of my head.
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
just go with 7.33's!!!
hahahaha just kidding.. you'll top out at 80..
i vote for 4.56's
i did calculations and stuff for my car.. when budget allows, i'll be heading to 4.30's for myself.. i top at 6500..
for you, at 7k(maxing out, highest you will go), in fourth(i'm guessing 1:1 for the tko), 28" tire, 4.56 gear, you will be doing 127mph.. more than enough for mid 12's, good till low 10's actually.. you should be trapping around or just above 6000 rpm.. thats 109+mph..
4.88's will push you to 119mph at 7k.. but if you go for more power later on, you may run out of gear one day..
i vote for 4.56's
hectre13
12-11-2023 08:14 AM
ambainb
04-25-2016 09:21 PM
hectre13
08-26-2015 08:17 AM
