anybody running XR276HR-12 cam and have a 383?
1 Post
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Re: anybody running XR276HR-12 cam and have a 383?
I've got what is essentially the next size cam, a 230/236 112LSA, and a Miniram intake, but otherwise have pretty much the same shortblock. My dyno runs were 396 RWHP and 383 ft.lb. You should have a higher torque number by 12 to 20 ft.lb, and slightly less horsepower.
sadly i only put down 310 rwhp to the wheels....at 5000 rpms bc i didnt upgrade the fuel pump or injectors but my torque is 350 ft/lbs and is a nasty lil torque curve.....motor has 500 miles on it hehehe
1 Post
Did you log fuel pressure and air/fuel ratio? Did it lean out on the top-end? You shouldn't have run out of cam for another 800 RPM or so.
Jvette, did you finally get that thing dyno tuned all the way?
thats ab the same numbers i got with a slipping tranny and non lockup converter
Last edited by 89formula350b2l; 08-27-2007 at 08:57 PM. Reason: Automerged Doublepost
Car: 89 vette
Transmission: a4
Not yet. It's my daily driver so no rush. I will tune it at the track when it cools down!
John
John
