Switch panel pictures
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
Have any of yall switched over to switch panels, like Moroso's or painless's? I have searched all over and cant find any that have been installed cleanly in a third gen. someone help me on so pics or of a mounting location thanks
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
made my own out of thin guage aluminum from home depot. Bought the switches online and drilled out a few holes. How many switches do you need? I installed an all autometer guage cluster and added 4 switches under those guages as well as one switch under the headlight switch for my ignition kill.
Here is what im thinking, I have a radio delete plate right now (its an original GM part) so i dont wanna chop it up. and i have a Moroso switch panel, with 5 switches and one start button, and 5 circuit breakers. So i think im going to get a piece of sheet metal, and trace out the radio delete plate on it, and then trace the moroso plate on it, drill it out and put all the moroso switches and circuit breakers in it. what do you think? BTW, i need a switch for, ignition, water pump, fans, fuel pump, and NOS, and a start switch. Im redoing my engine harness so i only have around 10 total wire in the engine compartment, that is the plan anyways thanks
Car: 1984 Z28
your idea works for me, just use aluminum sheet metal since it'll be easier to cut and won't rust out at all.
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
mw66nova, I really like the plate you put in place of your ash tray. What did you use and how did you make it? Oh, and why did you change from your Megashifter to stock? I have one and was thinking of going back to stock but really wanted to have a good reason to switch.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
the megashifter was bulky and clumbsy and i never felt like i had a positive engagement when i shifted. the stock shifter is now fitted with a b&m gate and works great.
the panel in place of the ash tray was made from plexiglass. it was a pain in the butt to make but looked cool. the current one with the vacuum gauge in it is made from an old dash board.
B&M pro rachet(SP?) is the only auto shifter for me, i love mine.
But i should have my switch panel mocked up tonight and i will shoot a picture of it and see what yall think. i think i will be pretty nice
here it is, the interior is a little (a lot) dirty, please excuse the mess,
Ghettobird52
07-05-2024 11:18 PM
