i ran a 14.7 wtf
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
i ran a 14.7 wtf
lol that was good for the problems i was having motor was not doing well the cam had a lope gone but didnt find it out till i had made a run and it was in second gear around 5000 rpm backfiring and the back barrals was not opening and i messed over shifted second gear and had to down gear
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
ouch.. been there, done that.. my dad could only hit mid 14's on slicks.. i had 6 lobes ground down, and was barely running on 7 cylinders..
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
hopefully no real damage besides that was done!
What kinda times were you normally pulling that sounds like a healthy setup!
Car: 1984 Trans Am
i never really got a good run in with that motor.. ALWAYS miss-shifted(foot was too fast for the shift, haha) but my best was a 12.76 @107, 1.8 60ft, missed shift 4th.. that was probably a better setup than what i have now.. made TONS of torque down low..
it was a:
10.76:1
383
Brodix RaceRite 200's
--2.055"/1.600" valves
--cleaned combustion chambers
--SOLID ROLLER SPRINGS(this was why my cam went down, didnt do my hw)
RPM Airgap manifold
800EPS carb(edelbrock)
comp 294S cam
--solid flat tappet
--.525"/.525"
--248*/248* @ .050"
it was a:
10.76:1
383
RPM Airgap manifold
comp 294S cam
--solid flat tappet
--.525"/.525"
--248*/248* @ .050"
Car: '82 Z28
Huh same cam I'm running. I just used whatever springs came with the AFR heads, think they were for a hydraulic cam. Sucks you wiped it but at least it's an easy fix. Friend of mine likes to put used cams and flat tappet lifters in his engines... kept telling him he shouldn't do it "oh, I've never had a problem". Finally bit him in the butt and he wiped a cam hahaha.
Car: 1984 Trans Am
well when i found out my cam was gone, it was pretty bad.. but still fixable.. i tore down the motor, cleaned the block like my life depended on it, all new bearings, had to polish the crank a bit(it was that bad), new cam/lifter set, timing set and valve springs for THAT cam.. from brodix, the pressures were 240# @ seat.. i'm running about 135# @ seat right now.. well after the rebuild, it happens AGAIN!!!! one lobe freakishly gone down after 300 miles.. so ANOTHER rebuild had to happen.. i really liked the 294S cam but wanted more topend so in went a 306S, where i'm at now..
i'll be going solid roller if/when i grind down this cam.. i would love to be maui's only streetcar in the 10's on just motor.. most guys are in the high 11's on motor.. 2 cars are in the 10's.. one has a 14-71 blower on a fully built 350, the other is a nitrous(100shot) supercharged(low boost) 360 in a dodge dart
darwinprice
17
10-11-2015 11:51 PM
Linson
10-01-2015 09:50 PM
