racing harness questions
Car: 87 IROC-Z
Engine: POS 305
Transmission: 700-R4
Axle/Gears: DUNN0 STOCK DISK BREAK 10 BOLT
i was about to put the plastic racing seats in my car with some sparco racing harnesses when a friend told me that my harnesses are out dated because they have to be replaced every 2 years could any one conferm that?
is there a website i could find up to date info on stuff like that?
thanx
thanx
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Are you running quick enough to require a 5 point harness? That normally means 11.49 and quicker which requires a roll bar. If you're running slower than that then the rules say you don't require a 5 point harness and factory belts will do fine. Since the 5 point harness isn't mandatory, the expiry date doesn't matter. If you do run quick enough that you have to have the 5 point harness, the belts expire 2 years from the date stamped in the tags.
That's the rules however track rules may say even the slower cars using a 5 point harness must have them with valid date codes. Call your local track to ask but I doubt there will be a problem.
Those "plastic" race seats also need to have the back of the seat braced. That means attaching a bracket to the back of the seat near the top and attaching it to the crossbar of the roll bar to be track legal.
