question for 1bad406
hi i was wondering how much you let the front susp on your car extend. when your set up for 7.0 pro tree how much difference is there from no limiters.also what size front tires do you run thanks for any advice you can offer. i am trying to get my car set up for 7.0 this year thanks Ed
Car: 1987 Camaro
Engine: 406
Transmission: Powerglide
Axle/Gears: Moser 31 spline / 4.86
hi thanks for the info. i was worried about traction problems with no ext. the chains are installed gonna test it in a week or two. found some problems with eng hope the changes get me the couple of tenths i needed.i have 26 in tires on the front i will probably have to change as i doubt my car will react faster than yours. do you run a pro brake? thanks again for the info Ed p.s. .417 worst is pretty sporty hope i can just get close to that
Car: 1987 Camaro
Engine: 406
